i cant find the proper thread so im going to ask here, i need a backdoor password for a ddec3 - 06r0160193, can anybody help or tell how to find the passwords with ddct? thank you for any help.
use text edit, drag the password parameter into the smart text editor and you will see the pass.
hi DKS
I have a problem with a ddec 4, the engine not have a jake brake, but, I install one, I modified the ecm but dont work, this is my method:
IO CONFIGURATION
Digital inputs
D_in_K2_funtion change to jake brake 4 enter
D_in_k3_funtion change to jake brake 2 enter
Digital Outputs
D_out_s3_funtion change to jake brake 4 enter
D_out_t3_funtion change to jake brake 2 enter
Diagnostic
Digital Oupts
Active_diagnostic_enable S3 change to 1. 0 a 0.0
Active_diagnostic_enable T3 change to 1. 0 a 0.0
Drive_diagnostic_enable S3 change to 0. 0 a 1.0
Drive_diagnostic_enable T3 change to 0. 0 a 1.0
passive_diagnostic_enable S3 change to 0. 0 a 1.0
passive_diagnostic_enable T3 change to 0. 0 a 1.0
I am doing something wrong?
THANKS EXCUSE ME FOR MY BAD ENGLISH
is ok i try
could someone help me with a stock cal. for 06R0855712. The ecm was tuned by someone and ever sense The manual fan and jakes do not work so I would like to do some comparison. Thanks
which is better ddrs or DDCT?
You need to select the retarder type to jaco/pac use the function search to find it.
Sent from my GT-I9500
Share and use the THANKS button and from time to time somebody will help.
PD. Use the REPUTATION button too.
colh (11th July, 2016)
hola necesito la clave para sis 2009b ss316248203c7df6bd3b4f6a7c muchas gracias
Is there a way to compare ecm programms with dct? I know how to compare two cals with calterm but not dct? Is it split and compare or something along those lines? A little explenation would be really appreciated..
Yes, a litle icon with a magnify on it.
Or you can open the panel "compare"
