Page 22 of 25 FirstFirst ... 12171819202122232425 LastLast
Results 316 to 330 of 368
  1. #316
    Apr 2016
    Quote Originally Posted by acid325 View Post
    amashmafia i made a couple of 12 mpg serie 60 on laod this possible overboost is not really= to overfuelling i can made you a cal with 50 psi no smoke and 900 og egt
    depend of your timing and everything you cannot change a number in pulse width and think all ajust by is self all creted too be like the cal is at the start you need too chaneg everything too make it work proprelly is easy change 2 number and run with high horse power i can do this but make a real cal is really hard
    Your PM is full. Do you have shop in USA? I can bring my truck for tuning.
  2. #317
    Apr 2016
    ".......... Where are you from and where do you run? I may know a shop that could help you out ..........." amishmafia00
    I am in Nevada, if you know good tuners around, please help.
  3. #318
    Apr 2016
    I have another question. Is it possible to accurately check the TDC on cylinder 1, without removing the injector 1. If this is not possible, before removing the injector, should I drain the coolant or not ? I don't want any coolant to go to the cylinder. Also, do I have to replace the O-rings of the injector and the bolt?
  4. #319
    Sep 2010
    To check tdc must remove injector. you do not have to drain coolant but if you do not drain fuel out of head it will go into the cylinder when you pull the injector. I cleared my inbox. I will check on shops in NV or nearby. Do you stay in NV?
  5. The Following User Says Thank You to amishmafia00 For This Useful Post:
    T520 (6th January, 2017)
  6. #320
    Apr 2016
    Yes! I am here.
  7. #321
    Oct 2013
    Just a Question Would Anyone know why in the DDEC Calibrations the timing table Has the Timing #s all Scrambled all over instead of more a Consistant Pattern ? I have been studying this and would appreciate if anyone could shed some light on this thanks ,,
  8. #322
    Sep 2010
    look at in in 3d view and maybe you will see a pattern or trend
  9. #323
    Oct 2013
    Ok thanks for the Suggestion just wonder what 3D Veiwer works for this ? Or is there a 3D View within DCT ? Thanks for sharing
  10. #324
    Jun 2017
    Ekaterinburg, Russia
    Friends, I ask for help. The PW determines the power and torque. Is there a table of power matching and PW? For example at PW = 40, what is the engine power? I apologize for the bad english. Thank you
    ps: for ddec 4
  11. #325
    Jun 2017
    Friends, I played with the pulse width table. I got the PW = 45 (with DDDL 1500 rpm, in treylor 45t). This is at Detroit 14, which has disabled the Egr. Turned out to be a monster. A month later the head of the engine broke down. Overheat. I think I needed to change the protection parameters, set shutdn_coolant_temp = 100 degrees Celsius, and shutdn_oil_temp = 105 ... Dear gurus, who can tell me what engine power I got if PV = 45 at 1500 rpm .. . thank you in advance for your response.
  12. #326
    Sep 2011
    Hey Guys i have a ddec2 engine just converted to ddec 3 ecm have changed bull gear setting motor us running but it hunts at idle and dosnt pull when loaded
  13. #327
    Oct 2013
    Have you Checked What the actuall PW is while you are loading the Engine ? If it does go to 45 at 1500RPM you probly pulling aprox 625HP
  14. #328
    Oct 2013
    Quote Originally Posted by smileyr33 View Post
    Hi do you Have DDDL ?
  15. #329
    DK Veteran hercamp's Avatar
    Aug 2009
    YOU NEED FLASH WITH THE RIGHT FILE , OR JUST PLAY WITH DCT ( NOT BASIC NOWLEDGE ) YOU NED CHANGE SEVERALSPARAMETERS AND DONE.
    IF YOU WANT I CAN MAKE A CAL FOR YOU BUT NOT FOR FREE..SORRY
    .A LOT OF PEOPLE TAKE ACID FILE AND SOME OF MY FILES AND RESELLS THE WORKS AND KEEP THEIR POCKETS WITH MONEY FROM THE WORK OF OTHERS .
    the life is easy... people complicate!!!!!!!!
    life is funny just step away of people that wants make your life a shixx
    http://youtu.be/PEw3nYmpEys
  16. The Following User Says Thank You to hercamp For This Useful Post:
    amishmafia00 (19th November, 2017)
  17. #330
    May 2010
    Hi guys. I have a DDEC 4 and I need to change the ratings. With DDDL it has 2 ratings available - one is 430/500 and the other is 430. i want to make it a 500 not 430/500. With DDRS I see it has rating 0 which is 500. but it will not let me change it to that. With DDCT I see under customer changeable options it has ratings allowed and that value is 58. Do I need to change this to get my rating 0 - 500 option? Or is there something else i need to change so enable the option 0 - - 500
