hass42 (28th April, 2017)
Hi anyone tried making a w167 or w254 key with avdi, i have lost key on a w167 ?2013-14
i did
most threads are too large to find useful information easily
or if they are short they tell you how to do it
or what not to do
they dont actually explain WHY it is done
Is it possible to read isn on msd81 bmw ecu on the bench with avdi?
The reason AVDI downgrades the CAS from the latest ISTAP version is because AVDI can't read the data from the CAS when it has the latest version... After it downgrades the CAS, it is able to read the data, then insert key data.. Then if you have the ISN from the car (DME) you can overwite the CAS ISN, then encrypt, then sync the DME to the CAS and you have a working car again... The problem is... (and this is just my thoughts) BMW and the aftermarket play a game of leapfrog, BMW comes out with a new update to keep the aftermarket from taking there business, and the aftermarket figures out what they did... Then BMW comes out with a new update... and the process goes on and on... I personally think that BMW has a new update that when it sees somebody trying to downgrade the CAS, it tells it to disregard the key slot... or BMW is keeping data in a different place in the flash, and when you downgrade it, you just put the key data where the info as to where the key slot was... I wish I had more time to play, I would find one of these cars with the latest flash and pull the CAS and read it on the bench and compare to a CAS that is an update or two back... I wish that if anyone is having an issue, and Abrites gets notified, they would send out and email and say there could be a problem and we are working on it.. I just can't take being blown off...
Ivo88 (2nd May, 2017)
Can you tell me where to bay it genuine BE keys.I was trying from three difference suppliers with no luck none of work with protag.
tkmotors (3rd May, 2017)
Anyone done a Mercedes etc gearbox programming with avdi, 722.9 electronic board is new . i cant seem to personalise and activate it. Anyhelp appreciated
new ones need scn coding
DONT FORGET TO LEAVE THANKS + REP!!
DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
Ive tried transferring scn coding but dosnt work just cants see it activate
