Page 358 of 373 FirstFirst ... 258308348353354355356357358359360361362363368 ... LastLast
Results 5,356 to 5,370 of 5594
  1. #5356
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
  2. #5357
    salkapone's Avatar
    Oct 2013
    Hi ,,,,Seat Leon my 2015 VDO MQBAB dash unable to make service mode trough OBD wit latest update !! latest update not cower all MQBAB ??
    Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
  3. #5358
    not even cover all because NO TOOL IN THE WORLD THAT COVER MQB!!!
    hello wake up!
  4. The Following User Says Thank You to i-vtec For This Useful Post:
    shafo (18th October, 2017)
  5. #5359
    Dec 2012
    EU
    Quote Originally Posted by ps80l View Post
    Its amazing how bad the Mercedes user manual is. I have no clue where to connect the fuse plug from the ZN051 box. Saw some videos but couldn't find the connection for the 2005 R171. Should I use fuse 65 in the SAM module? Don't even know if it has the same fuse layout as w211.
    What r you trying to do?
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  6. #5360
    Mar 2017
    Used the Side fuse box and connected to Fuse #36. Everything seem to go fine but it was taking for ever. At 40 minutes it was barely on 200 attempts out of over 8000...
    Videos show to turn ignition with IR key. I couldnt do that with the R171...
    Seems like relay box wasn't doing anything as the search was so slow.
    Took out EiS and made key with eeprom...
  7. #5361
    koln, germany
    FUSE SHOULD BE CONNECTED TO EZS FUSE IN BOX , THIS WAY IT ALLOWS YOU TO MAKE IGN ON WITH IR KEY
    TAKING OUT THE EZS IS THE FASTEST WAY TO DEAL WITH
  8. #5362
    Mar 2017
    Fuse 36 is for EZS..than I connected both red cables into relay location on zn051 box.
  9. #5363
    salkapone's Avatar
    Oct 2013
  10. #5364
    Hampshire
    Good tool, but their speciality is millage correction, just spoke to their dealer in uk!
  11. #5365
    Aug 2015
    Quote Originally Posted by salkapone View Post
    Also key learning posdible ?
  12. #5366
    Rito's Avatar
    Someone have problem in AVDI kill new BSI continental 2015+ ??
    It have some bug in thine new upedate........
  13. #5367
    whiskeyman's Avatar
    Dec 2010
    how did it get killed
    pulling pin?
  14. #5368
    koln, germany
    those bsi needs to be reflashed
    i heard from a friend in peugeot that they are updating car bsi s to avoid people pull pin from car
  15. #5369
    yeas because avdi was the first tool in the world that kills this bsi by obd
  16. #5370
    BTW. no update was in august, i wonder we see any update in october?
    ...and have you read the update info about bmw, he wrote that bmw online will be possible read ecu thru boot mode, change fem and next abrites delete that info!
    Hello AlekN what the hell you doing?
