Caterpillar TMI (Technical Marketing Information)
Page 1 of 4 1234 LastLast
Results 1 to 15 of 59
    Top Poster SaMirakle's Avatar
    Jan 2011
    Default Caterpillar TMI (Technical Marketing Information)
    Attention everyone! If you require any information from the Caterpillar TMI (Technical Marketing Information) system I can provide you the information if you give me the ESN (engine serial number)
    For those who don't know about TMI, it provides the following information:
    - Engine Test Results
    - Complete Flash File History with update revisions (if applicable)
    - Gasket kit information (numbers, service indicator, etc.)
    - Complete Test Specs
    - Torsional Information
    - Emissions Data
    - Systems Data (Air Intake System, Cooling System, Engine Spec System, Exhaust System, Fuel System, Lube System, Mounting System, Starting System)
    There is a lot of technical information contained in TMI. If there's a specific engine you want this information on then just let me know. I should be able to provide you with a full PDF file for it!
    ---:..Gratitude is the best attitude..:---
  2. The Following 2 Users Say Thank You to SaMirakle For This Useful Post:
    dupisa (13th May, 2018), epascoe (11th February, 2018)
  3. #2
    Feb 2009
    Default Cat
    Please TMI for Cat engine 3116 S/N :1167959.Thanks.
    Jan 2011
    Quote Originally Posted by AdnanB View Post
    The S/N has to be at least 8 digits long. That's incorrect.
    Sep 2010
    Hello I need the tmi to lower it if it is possible thank you
    Jan 2011
    Quote Originally Posted by lucianocasco View Post
    Give me the engine serial number so I can look up the information for you.
    Sep 2010
    Queria to know if not this one in dvd the tmi to have it does not matter q is current, I work with new engines and not so much, thank you
    Jan 2011
    Okay. Sorry im still not understanding what you need...
    please, need for C15 engine s/n LHX02345.
  10. #9
    Jan 2011
    Quote Originally Posted by lgalvezpa View Post
    Here you go
    https://rapidshare.com/files/457401978/TMI_Files.rar
    That should be everything you need.
  11. #10
    Top Poster c16man's Avatar
    Dec 2010
    South Africa
    Hey SaMirakle, need TMI for C6.6 ser 66607075 please, or is it possible for the entire 666 range?
    Thanks in advance!
  12. #11
    Jan 2011
    Quote Originally Posted by c16man View Post
    Thanks in advance!
    I don't believe that's a valid Caterpillar engine serial number! It should have 1 or more letters in it. Not just numbers.
  13. #12
    hello samiakle ,need tmi info for my mxs33185 if u be able to provide info for hp 475 hp 500 hp 550 hp 600 hp 625 fls fts setting also that be really really appreciated thanks very much
  14. #13
    Jan 2011
    Quote Originally Posted by cabby176 View Post
    Here you go:
    https://rapidshare.com/files/459143061/TMI_Files.rar
    I'm not sure what you mean about fls/fts settings. I think you need the factory passwords, is that correct? If so then you need to upload the html file that CAT ET requests for these passwords.
    I hope the TMI files help you for what you're looking for!
  15. #14
    Dec 2010
    South Africa
    Quote Originally Posted by SaMirakle View Post
    Yep that is a valid CAT ser nr, the C6.6 engines are the same as the 1106D Perkins engines. Did have access for a while to SIS and in the engine information section the C6.6 series cannot be found. The ser no cannot be found.
    Where can this info be found?
    But the parts manual and omm, shop manual etc can be found on SIS.
  16. #15
    Jan 2011
    I'm not sure. I was using SIS online as well and it could not access anything with the serial number you gave me. It might be a very old engine or something.
    You may want to try contacting Caterpillar or something.
