How to change COM port settings using USB-to-Serial Adapter - Page 3
Page 3 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 123
  1. #31
    Amsterdam
    I have Dream up for Dm 500, I don?t have the zipfile so I cannot upload it, if somebody wants it mail me.
  2. #32
    May 2009
    birkenhead merseyside uk
    just installed my adapter(usb 2 to rs232 converter)..bought off ebay ..i had to connect it to my vista laptop then load the cd into the driver ,, was a little confusing but read the readme which says to pre install from cd then to unplug restart computer the attach to computer again and let windows install,, took a few minutes but it installed ok and managed to flash my box using dreamup... hope this helps others
  3. #33
    I do not know why this software is not available in the IT webside
  4. #34
    I am looking for usb-RS232 converter, It looks fine. but, Does anybody know about similar drivers?
  5. #35
    DK Veteran ianmac's Avatar
    Oct 2008
    Luton
    Quote Originally Posted by Zonic View Post
    Have a look here @ post number 193:
    http://www.digital-kaos.co.uk/forums...2/index13.html
    & you will see usb serial drivers for all these window versions...
    System Requirement:
    . Supports the following Windows OSes:
    - Windows 98SE
    - Windows ME
    - Windows 2000 SP4
    - Windows XP SP2 and above (32 & 64 bit)
    - Windows Server 2003 (32 & 64 bit)
    - Windows Server 2008 (32 & 64 bit)
    - Windows Vista (32 & 64 bit)
    - Windows 7 (32 & 64 bit)
    Hope this helps
    Ian
  6. #36
    Junior Member avo24's Avatar
    living in centre of Singapore
    HI all.. I am news here.. I using a china box DM900-c2 .. I would like to know which software can it mod my DM900-C2.. and what is the PASSWORD for DM900-C2.. PLZ all help me ..PLZ
  7. #37
    bushey herts
    Quote Originally Posted by smirnoff_rules View Post
    setting to change your com settings
    Start -> Control Panel -> System -> Hardware -> Device Manager -> Ports (COM & LPT) -> Prolific USB to Serial Bridge… at this point, take note of the COM number. Use that number when assigning the COM port
    in your Device Manager and double click your USB to Serial adapter. Click Port Settings and then Advanced. You should then be able to select the COM port (1, 2, 3, or 4) being careful not to select a COM port already in use on your computer.
    if u only have printer and com then change the com one in the drop down box
    thanks for all your help as I need as much help as poss
  8. The Following User Says Thank You to Bluezola For This Useful Post:
    promalta (13th April, 2013)
  9. #38
    Default i have the same problem
    my rs232 with adaptor works fine with usb converter, but wont detect with dreamup
  10. #39
    DK Veteran harky's Avatar
    i using win7 ... usb successful install but dreamup not working??
    do anyone had successful used dreamup with win7?
  11. #40
    Quote Originally Posted by harky View Post
    Hi Harky,
    Does dreamup start at all? Or does it come up with an error stating that COM port is not found. If dreamup starts but cannot communicate with the dreambox, some possible reasons are as follows:
    There are a number of USB->RS232 adapters out there. Problem arises from some of them: 1. being non-bidirectional (i.e. doesn't let the dreambox communicate back to the PC) 2. reverse the polarity on one of the TX / RX lines.
    First try the Null modem cable with a computer that has an original COM port. Once you know the Null modem cable works. You will have to try with a few USB->RS232 adapters...
    Cheers,
    James
  12. #41
    i had a Null modem cable but i want to try usb one so i bought a direct USB->RS232 cable.........
    do i know to change the port if i had install the driver successfully?
  13. #42
    Default same
    i also have the same problem
  14. #43
    i had
    this device cannot start. code 10 windows 7
    but cant find any solution.. anyone know?
  15. #44
    How can I change settings to connect my deambox 500s with my computer?
  16. #45
    I am thinking on reinstalling a new windows(got w7 x64
