Page 6 of 9 FirstFirst 123456789 LastLast
Results 76 to 90 of 123
  1. #76
    Nov 2011
    Default Com Port Settings
    I have a Linksat 900 Satellite receiver and am trying to upload some data using a USB to serial adapter but cannot access the ports I have uploaded PL 2303 Prolific driver but can't complete upload any help please
    Adrian Ash
  2. #77
    Jun 2012
    Default need null driver for vista
    Can someone provide me with the null modem driver for vista. Im using usb to Rs232 but the driver doesnt work...need to flash my dreambox....
  3. #78
    Jun 2012
    Default hellpp please!
    hi,
    i have a dm500 and every single image i try to flash comes up with error! upload aborted, even when i try to do the original
    i have already tried to change the com port settings but there is no 56.000 setting available
    although my box is a clone (i think) because it says electro multimedia on the front, i think i must be doing something wrong?
    the box itself has no image on it at the moment so dreamup is my only option
    someone please save me, been stuck with this dilemma for 3 months and about to give up hope!
    ps im using a usb to serial converter and i have the correct drivers on because dreamup does recognise the box after a few tries
    thank you
  4. #79
    Sep 2011
    could someone help me set up my usb link to run the bluetooth. when my laptop detects the device it asks for a pairing key and do not know where to get that key
  5. #80
    Can someone help me on the driver for RS232 to USB .Apparently the PL2303 does not work for me at all.Can someone help i am using window 7
  6. #81
    Aug 2012
    Default test1234567890
    Quote Originally Posted by jimbo69jones View Post
    A lot of the cheapy USB>Serial adaptors sold on ebay use a TI chipset, and the drivers can be hard enough to find alright. I've attached the drivers I managed to find and I hope they help. They are actually for a USB>Mobile serial phone lead, but they have worked on several non-branded serial leads as they use the same chipset. Cannot hurt to try.
    test1234567890
  7. #82
    Oct 2012
    same problem
  8. #83
    Oct 2012
    same problem with usb to serial from ebay, blue color the connectors.
  9. #84
    Oct 2012
    hi guys,
    i am new with flash.
    But advise if i bought the correct stuffs for flashing DM500C
    1. Null Modem Cable. (9pin female to 9pin female)
    2. USB to 9 Pin male USB adaptor
    I am using Window XP. Kindly if this is what most of you guys are having issues with? And if i got the correct stuffs?
  10. #85
    Jan 2013
    Same problem here, might have to buy a better cable, one with some support.
  11. #86
    Dec 2012
    The USB to Serial converters tend to give many problems. I had the same problem of upload aborted while using the converter.Solution is to buy a PCI to Serial card and install it in your desktop PC. Guaranteed to work, tried it myself.
  12. #87
    Jan 2013
    Default about drivers
    that is kind of you . i have suffered a lot with this problem. i hope it will work with me
  13. #88
    Feb 2013
    prolific clone
  14. #89
    Feb 2013
    i need help with usb to com adapter dreamup cant recognize
  15. #90
    Feb 2013
    Dreamup older version solved my problem of not connecting to DM500s
