Page 7 of 9 FirstFirst ... 23456789 LastLast
Results 91 to 105 of 123
  1. #91
    Feb 2013
    Default Flashing a dreambox
    Hello DK, please can you help me with my DM 500C.
    I'm new here (2-3 days active) and my english is not very good.
    I read a lot on this site and still didn't solve my problem.
    I want to flash my dreambox and i follow steps from here:
    http://www.digital-kaos.co.uk/forums...ox-dreamup-33/
    Cabel i use is USB on one side and Null modem on the other side.
    And this is backside of Dreambox:
    And i can't use original Null Modem Cable because my laptop don't have that input.
    I only have 15pin input (rs232):
    Now I try to use that Guide from Devilfish and i try it with two different DreamUp versions (V1.3.2.1 and V1.3.3.9) but nothing happens.
    I don't see this: "bootloader should be copied to the box" and I dont get that message: 'Box attached and Ready'
    I'm sure I use right Port for the connection (COM9).
    There is 14 different Ports i can choose and i try all of them.
    It's still like this, nothing happens:
    Please what to do next??
    Is there some other versions of DreamUp or some other software??
    I'm very thankful for your help.
    Best regards
  2. #92
    Feb 2013
    I have now tried 6 different versions of DreamUp and still nothing.
    My computer just can't recognize this Dreambox.
    I also tried with network cable but still no help.
    This can't be so difficult.
    Last week I watched channels for free on this Dreambox
    and then my Cable provider do some new installation on wall
    and put a new Cable box there.
    After that all my channels disappeard and I can't find anything.
    I was trying some functions but no help and then i reset Dreambox.
    Now I want to start all over and need your help.
  3. #93
    Dec 2010
    Quote Originally Posted by La Manita View Post
    Which os r u using? If yr box able to boot up, there is no need to reflash.
  4. #94
    Feb 2013
    Quote Originally Posted by ypvs125 View Post
    I don't know but i think is Linux and I use Windows Vista on my PC.
    Yes it can boot but i reset it and don't know what to do next.
    I think if i flash it then i can install that firmware DK v1.1.
    And then i can search with transponder to find some channels.
    Correct me if i'm wrong.
    Maybe i don't get it at all. I'm not a expert.
    tnx
  5. #95
    Dec 2010
    tnx
    From the pic above, i think it is just a normal usb to serial converter and not a null cable although it looks similar. Previously, are u able to view the channels?
  6. #96
    Feb 2013
    Yes i watch channels last week with no problems and then i do a fabric reset on it because my cable provider makes some installation in my home which caused all channels disappeared.
    If i buy this original Null Modem Cable how do i connect it with my laptop??
    There is only 15pin input on my laptop.
  7. #97
    Dec 2010
    The first pic that on post #91, is that a null modem converter on the back of yr dreambox?
    Do have the backup image for yr box if u want to reflash it?
  8. #98
    Feb 2013
    Yes, it's a serial adapter i bought so i can convert it to 9pin female. (original input on dreambox is 9pin male).
    And you can see that usb-serial cable have 9pin male so i needed to buy serial adapter to use it.
    I don't have a backup image.
  9. #99
    Dec 2010
    Yr usb to serial converter is a male whereas yr dreambox is also a male end. U don't need the serial adapter on the back of yr dreambox. Buy the female to female null modem cable and u will be able to flash via dreamup. But if u did not backup yr image, how do want to begin with?
  10. #100
    Feb 2013
    So you'r saying that if i buy null modem cable i will connect one end to dreambox and the other end to USB-serial cable and so connect it to USB port on my PC ??
    Isn't it same if i use serial adapter. I connect it to male input on dreambox so i can use that USB-serial cable.
  11. #101
    Dec 2010
    Isn't it same if i use serial adapter. I connect it to male input on dreambox so i can use that USBserial cable.
    Serial adapter and null modem adapter are not the same although both can convert from male to female.
  12. #102
    Feb 2013
    Ok, i think i'll try with my brothers desktop computer that have 9pin male input and have windows xp installed.
    I will buy that sob Null Modem Cable ) and try to flash it.
    I just did backup image on my dreambox with Flashwizard.
    But i'm confused now after you say that if a dreambox can boot then i don't need to flash it.
    1. How do i know if there is a necessary image installed on it??
    2. How do i check what firmware this dreambox have??
  13. #103
    Dec 2010
    Flashing is needed when yr box is corrupt and not able to boot up. When u on the box, what is the start up screen?
  14. #104
    Feb 2013
    It's like this:
  15. #105
    Dec 2010
    It's like this:
    Your box is loaded with gemini image.
