Results 16 to 30 of 34
  1. #16
    kautuvera's Avatar
    Default ME 2.8 Transmisson to Manual
    Quote Originally Posted by MS1 View Post
    You are wrong M8 Mercedes did not implement SCN coding till 2003, if you have the right SDS version you can code me2.8 of-line. I made many ME2.8 2001-2002 virgin and code of-line. no problem. 2003 you need SCN Coding. As always there is a way around that i you know the tricks.
    You getting that code because the ECU looks at the vehicle configuration and it knows you have a Automatic Transmission, and cannot communicate with it so directs you to the transmission to correct the problem.
    Go to EZS adaptation and select manual transmission.
    See the screenshots
    I got all things Ceck destination was correct , the problem is the ME motor unit , you can change the destination ?
    any help please
    really i want your help....
  2. #17
    Port Elizabeth
    Default ME 2.8
    Quote Originally Posted by kautuvera View Post
    any help please
    Hi there why not just change over those two chips I did this to a c320 the donnar vechile was a e320 eveyone said wont work al I did was change chips and started vechile it was better than paying 3000 pounds for a new one and I had all the right settings from original ECU
    Hope this helps goodluck
    Shane!!!
  3. #18
    USA
    any help please
    Program this bin to the eeprom and go to ME and do initial startup, that will allow you to change the engine selection. follow the instructions on the SDS screen.
    This will guide you thru the process of entering the VIN number
    Synchronies ME to EIS and Activate DME. When it ask you for the engine model make sure you select the correct one
  4. #19
    kautuvera's Avatar
    Transmission mode for changing the engine unit from automatic to manual I need password , can anyone help me ?
  5. #20
    Remove the password so easy ! guys some Mercedes Virgin programs kill the ECU SCN coding because it delete most of the lines , we only need to change a few data to unlock the ECU , i had w220 i virgin it with mercedes virgin ECU program then the car did't start and i had same problem but when i virgin it manual it worked , i had to SCN the car to make it start . i don't hide any things for you mat but idon't like people who just want info and they don't search and they don't " thank " as well
    Have a nice day all
  6. #21
    so guys ? Nothing happen ?? the one who said nothing is nothing he don't know nothing YET ! ME2.8 have SCN for sure but there is ways to change values ,
  7. #22
    Aug 2010
    You have only in ME fault code? ESP is clean?
  8. #23
    no need pass , its so easy
  9. #24
    man u still have this problem?? if so .. i will scn it for you or do it in other way contact me , i like to help people who need a real help
  10. #25
    Sep 2010
    do you have a way to provide offline scn coding? pm me if you do thanks!!!
  11. #26
    hi, sure there are many ways to offline coding , one of them by change the data manual in Factory data , and there is other way much easy if you dont know about binery codes , for me i save most of the cars factory data and put in other cars .
  12. #27
    daynight's Avatar
    Nov 2016
    EU
    Need help about issue. I try to code ME2.8 without Getriebe by CAN but when i put coding, DAS report: Communication error. In previous experience successfully code with CAN. Now i cannot turn off. What need to be next?
  13. #28
    france
    hello
    someone can help me to do adaptation a virgin ecu me 2.8 clk 320 w209?
    the old ecu is burnt
    except the 29f200
    the 5p08c3 is dead...
    i have witten the sin immo file adde her
    i don t have knowledge in mercedes cars
    i just want to help a friend.
    best regards to all!
  14. #29
    france
    oips! i forgot the file!
    i added also the 5p08c3 bin of the new ecu(before make it virgin)
  15. #30
    france
    hello :
    if someone can help me to adapt this ecu manually...
    would be great
