bogege (21st February, 2018), Decode Ghost (24th February, 2018), irfa (21st February, 2018), masterskay62 (21st February, 2018), mat17c (21st February, 2018)
File Name: 24c64 unknown code.bin
Unit: Siemens VDO CD70
EEPROM: 24c64 EEPROM
Vehicle:
Security Code:0363
Serial Number:GM007050045139
Part Number:13188465
Hardware ID:13187941
Ident:LG
Code Index:00204
Audio Index:02404
Wait Time:Not Running
Remaining Attempts:10
Decode Ghost (24th February, 2018), mat17c (21st February, 2018)
Hello guys!
Security code is incorrect probably. When I tried to disable anti-theft security it was impossible - programming failed when I used 0363 pin.
Any ideas??
Matt
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
Hello!
Headunit was not unregistered, so I changed dump to virgin and did it this way.
Regards and thanks for help.
Matt
Here is mey radio with needed sec code to learn with the unit......the old navi is dead, and buyed one without cid(display)....and must deactivate security.Here is my dump....
but here is two eeprom of 24c64... one inside the shielded plate and one at lower side.
I readed the inside shielded plate eeprom.
thanks.
Code is 5893.
Do you have a sticker on radio? Can you make a photo?
Decode Ghost (25th May, 2018), illestibor (30th May, 2018), rafal (24th May, 2018)
5893 is correct
need help
now my goal is to buy xp-005
who will help?
And here is a dump from the another CD70, that was unpaired - https://mega.nz/#!FGJGUSbS!SVinnhcd9xusCQ2r9bEsZhq9ClB-GzjR9iNDoEs97Ag
You can put in in EHU and pair with DIS using code from DIS. Is the code from display is known?
Decode Ghost (25th May, 2018), illestibor (25th May, 2018)
How can I solve this problem? I have CD70, my old display now broken and missing some parts so I cant plug it in and Divorce it. I also have other display and it says display safe(I guess its not divorced from other car too..)
mariuso2o (25th May, 2018)
