Page 3 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 122
  1. #31
    Sep 2016
    Hello guys.
    Could anybody help me with code???
    Regards
    Matt
  2. #32
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by mat17c View Post
    Hello guys.
    Regards
    Matt
    try code 0363
  3. The Following 5 Users Say Thank You to smoggy For This Useful Post:
    bogege (21st February, 2018), Decode Ghost (24th February, 2018), irfa (21st February, 2018), masterskay62 (21st February, 2018), mat17c (21st February, 2018)
  4. #33
    Jan 2017
    File Name: 24c64 unknown code.bin
    Unit: Siemens VDO CD70
    EEPROM: 24c64 EEPROM
    Vehicle:
    Security Code:0363
    Serial Number:GM007050045139
    Part Number:13188465
    Hardware ID:13187941
    Ident:LG
    Code Index:00204
    Audio Index:02404
    Wait Time:Not Running
    Remaining Attempts:10
  5. The Following 2 Users Say Thank You to Phatworx For This Useful Post:
    Decode Ghost (24th February, 2018), mat17c (21st February, 2018)
  6. #34
    Sep 2016
    Hello guys!
    Security code is incorrect probably. When I tried to disable anti-theft security it was impossible - programming failed when I used 0363 pin.
    Any ideas??
    Regards
    Matt
  7. #35
    shooting's Avatar
    Feb 2010
    WALES
    Hello guys!
    Any ideas??
    Regards
    Matt
    Probably because this radio is new to your car and so 0363 is not your pin...
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  8. The Following User Says Thank You to shooting For This Useful Post:
  9. #36
    bank's Avatar
    Feb 2017
    Ukraine
    Hello guys!
    Any ideas??
    Check mid speed can bus settings for DIS, EHU. Settings for ECC, UHP, DAB must be the same.
    Display paired with this radio? Post dump from display here
  10. The Following User Says Thank You to bank For This Useful Post:
  11. #37
    Sep 2016
    Hello!
    Headunit was not unregistered, so I changed dump to virgin and did it this way.
    Regards and thanks for help.
    Matt
  12. #38
    Feb 2010
    Romania
    Default need pn for cd70 navi
    Here is mey radio with needed sec code to learn with the unit......the old navi is dead, and buyed one without cid(display)....and must deactivate security.Here is my dump....
    but here is two eeprom of 24c64... one inside the shielded plate and one at lower side.
    I readed the inside shielded plate eeprom.
    thanks.
  13. #39
    bank's Avatar
    Feb 2017
    Ukraine
    Code is 5893.
    Do you have a sticker on radio? Can you make a photo?
  14. The Following 3 Users Say Thank You to bank For This Useful Post:
    Decode Ghost (25th May, 2018), illestibor (30th May, 2018), rafal (24th May, 2018)
  15. #40
    rafal's Avatar
    Jul 2010
    UK - PL
    5893 is correct
    need help
    now my goal is to buy xp-005
    who will help?
  16. #41
    bank's Avatar
    Feb 2017
    Ukraine
    And here is a dump from the another CD70, that was unpaired - https://mega.nz/#!FGJGUSbS!SVinnhcd9xusCQ2r9bEsZhq9ClB-GzjR9iNDoEs97Ag
    You can put in in EHU and pair with DIS using code from DIS. Is the code from display is known?
  17. The Following 2 Users Say Thank You to bank For This Useful Post:
    Decode Ghost (25th May, 2018), illestibor (25th May, 2018)
  18. #42
    Feb 2010
    Romania
    Quote Originally Posted by bank View Post
    so here is tthe label from navi EHU
    Thanks for help.
  19. #43
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by illestibor View Post
    Thanks for help.
    Here is your CD70 unregistered, pair using currect display pin
    wbr
  20. The Following 2 Users Say Thank You to shooting For This Useful Post:
  21. #44
    Junior Member mariuso2o's Avatar
    May 2018
    How can I solve this problem? I have CD70, my old display now broken and missing some parts so I cant plug it in and Divorce it. I also have other display and it says display safe(I guess its not divorced from other car too..)
  22. #45
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by mariuso2o View Post
    Read dump from old broken display and read dump from new display and post here
    wbr
  23. The Following User Says Thank You to shooting For This Useful Post:
    mariuso2o (25th May, 2018)
