CrossEPG Full Sly EPG - Page 2
Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 99
  1. #16
    DK Veteran andy211081's Avatar
    May 2009
    Doncaster
    my file looks like: so where do i put /usr/crossepg/crossepg_epgmove.sh
    #!/bin/sh
    prefix=/usr
    exec_prefix=/usr
    datarootdir=${prefix}/share
    if [ -x /usr/bin/showiframe -a -f /usr/share/backdrop.mvi ]; then
    /usr/bin/showiframe /usr/share/backdrop.mvi
    fi
    # hook to execute scripts always before enigma2 start
    if [ -x /usr/bin/enigma2_pre_start.sh ]; then
    fi
    if [ -d /home/root ]; then
    cd /home/root
    fi
    LIBS=/usr/lib/libopen.so.0.0.0
    #check for dreambox specific passthrough helper lib
    if [ -e /usr/lib/libpassthrough.so ]; then
    LIBS="$LIBS /usr/lib/libpassthrough.so"
    fi
    LD_PRELOAD=$LIBS /usr/bin/enigma2
    # enigma2 exit codes:
    # 0 - restart enigma
    # 1 - halt
    # 2 - reboot
    # >128 signal
    ret=$?
    case $ret in
    1)
    /sbin/halt
    2)
    /sbin/reboot
    4)
    /sbin/rmmod lcd
    /usr/sbin/fpupgrade --upgrade 2>&1 | tee /home/root/fpupgrade.log
    sleep 1;
    /sbin/rmmod fp
    /sbin/modprobe fp
    /sbin/reboot
    esac
  2. #17
    Feb 2009
    Andy,
    Looks like you already have the line in the right place.
    If you haven't entered it before you may have loaded an image which already have crossepg integrated, there are a few about!
    cheers,
    M
  3. #18
    swadlincote derbyshire uk
    Quote Originally Posted by andy211081 View Post
    does this work on UNOFFICIAL DREAM ELITE V.133DV3 PHOENIX EDITION which is enigma2? as i cant access file manager on my box?
    i think cross epg is in the dream elite server
    press blue button > addons or plugins (its one of the coloured buttons eg blue or green)> EPG
    its in there somewhere i have since flashed with DREAM ELITE and downloaded crossepg from the blue button .
    hope this helps
    DM800 Pro clone Merlin 3
    If a post was helpful use the button
  4. #19
    Quote Originally Posted by blogbytes View Post
    . However, my epg looks different to the one displayed on the pictures and I only get 2 days worth of epg. Will dig deeper, but am pretty certain it has to do with my xml file.
    are you using the "graphical EPG" there are a few EPG on a dream box "single EPG" "multi EPG"
    there is also "merlin EPG" witch can be downloaded and installed as a plugin
    or
    it might be iam using a diffrent skin
  5. #20
    Feb 2009
    Quote Originally Posted by 2685danny View Post
    you could try /usr/crossepg/crossepg.configure
    change the db_root=/media/thename of your USB device/crossepg
    you will have to create the crossepg folder (the one in green)
    db_root=/media/hdd/crossepg
    lamedb=lamedb
    providers=skyuk_astra2_28.2|krkadoni_skyuk_xepgdb
    force_load_on_boot=0
    download_daily_enabled=1
    download_daily_hours=4
    download_daily_minutes=0
    download_daily_reboot=1
    download_tune_enabled=1
    download_manual_reboot=0
    download_standby_enabled=0
    last_full_download_timestamp=0
    last_partial_download_timestamp=0
    csv_import_enabled=0
    show_plugin=1
    show_extension=1
    Hi Danny.
    I'm using an icvs gp3 image. I have gp3 plugin and tunisiasat plugin installed.
    I currently have my crossepg set to HDD. I have installed a 4gb usb pen in the back of my dm800 and it is recognised fine. my picons are installed on there and they work great.
    However..... I do not get a usb option in the configure crossepg storage device.
    I can also not find the /usr/crossepg/crossepg.configure as you suggest.
    Any help appreciated.
    cheeers,
    M
  6. #21
    Quote Originally Posted by Mithuk1 View Post
    Hi Danny.
    cheeers,
    M
    this is the file path /usr/bin/enigma2.sh
    you have to type or copy and paste this in it /usr/crossepg/crossepg.configure
    before the line LD_PRELOAD=/usr/lib/libopen.so.0.0 /usr/bin/enigma2
    make sure its the .sh enigma2 file
  7. #22
    May 2009
    Doncaster
    it works and dont know how
    Thanks for your replies though
  8. #23
    Top Poster PAUL7331's Avatar
    Mar 2008
    I dont have any option to change file to epg.dat
    Where is this? Im using the new ramaHAMMER gemini/vix image by the way.
  9. #24
    Apr 2011
    Quote Originally Posted by 78692 View Post
    does the line have to be added above LD....?
    because i did this on gemini dm800hd and now my box only half boots and gets stuck.
    Same here it ballsed up, what did you do ?
  10. #25
    Default epg
    hi iv been getting my self a dm 800 hd. i must say good bit of kit. still getting to know the box.
    im getting harddrive installed by a friend, and im wondering about the epg. my box is running Newnigma2 v3.1.1 firmware i dont know if any one knows this image, some people say that this epg download is in the plug ins, dose any one know if its in this image and how to go about installing it. dose any setting need to be changed? last thing i want to do i break the box.
    thanks for reading guys
  11. #26
    can any 1 help on this question????
  12. #27
    Default epg cant get to work
    im running nwenigna 3.2.2 and iv followed the post down to a t to install crossepg and it just isnt working. it goes through all the search and downloading but it just wont bring up epg. any 1 help!!!!!!!!!!!
  13. #28
    Quote Originally Posted by darguewin View Post
    have you tryed
    blue button > plugins
    or
    there is other epg sources in the plugins
    but cross epg works on most enigma2 images.
    there are others avaliable on the plugin servers but the ones that save the epg data to your flash / ram can fill up your boxes flash / ram and cause the box to crash (the green reboot screen)
  14. #29
    Default epg
    i just cant get it working. iv tryd all the epg out of pluggins and wont work. i tryed to re flash but all i got was check tuner config. tuner was set up as it should be but just kept comming up with that. so just had to put this newnigma2 back on. my tuner is rev m.
  15. #30
    Aug 2008
    Wild Mild West
    In newenigma the one to use is the xmltvimport located in the newnigma2 services from the blue button, once downloaded press blue button and select epgimport and set up your sources (blue button) and then manual (yellow button) and let it scan for your epg sources, it will then ask you to reboot and bobs your uncle.
    But i found that there has been some issues with the rytec server and it was playing up a bit so i chnged to crossepg, but you will need to add that plug in from the Tspanle plugin, once the Tspanle is set up on your box you can find the crossepg in addons / plugsins, and it works / set's up more or less like the xmltvimport, and it is working a treat.
    ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
