Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 99
  1. #61
    Senior Member canford's Avatar
    Aug 2010
    I uninstalled crossepg and installed crossepg_0.6.2-svn-260-r0_mipsel.ipk. but it never worked, have managed to install merlins epg and got that working,although not as user friendly as crossepg, its working and will stay with it until i can get crossepg working.
  2. #62
    Nov 2011
    Thanks for all the posts above. I have been having problems getting crossepg to work, hopefully I can sort this now.
  3. #63
    Apr 2009
    great tutorial thanks i managed to get full epg for each channel... only problem is...
    when i click 'multi EPG' (info>blue button) it doesn't load the multi epg... single epg works fine tho
    any sugguestions?
  4. #64
    Aug 2011
    any sugguestions?
    Hi, depending on your image you may have to enable multi epg,this is usually in the setup,customise menu.
    Good Luck
    Aus
  5. #65
    Nov 2011
    South Belfast, Norn Iron
    Quote Originally Posted by andy91 View Post
    Charming just added this line
    /usr/crossepg/crossepg_epgmove.sh
    Now my box only boots halfway and is stuck
    Andy,
    You edited it in wordpad or notepad?
    That screws it up as it messes with the text.
    Download the original enigma.sh from the link below abd it should boot again.
    git.opendreambox.org Git - enigma2.git/tree in /usr/bin
    Use notepad++ to edit it again.
  6. #66
    Nov 2011
    Quote Originally Posted by 2685danny View Post
    In Gemini Blue panel --> settings --> EPG:
    Make sure the top EPG options are all off. In the bottom panel use:
    File cache ..... on
    change the filename ...... epg.dat
    location ..... /media/hdd
    Automatically save ..... off.
    YOU HAVE TO CHANGE THE CACHE FILE NAME TO EPG.DAT, otherwise it will not work.
    Restart again
    What do I press to get the the blue panel/menu above?
    It isn't the blue button on my remote as it does something else.
  7. #67
    Apr 2009
    Quote Originally Posted by austenerife View Post
    any sugguestions?
    Good Luck
    Aus
    thanks for replying i'll have a look around & see what i can do
    i'm using latest gemini 5.10 image
  8. #68
    Aug 2008
    I followed all insturctions and it works, but when ever i restart my dreambox it now crashes, i have full epg working but the restart creates a log file when it crashes, any idea why? i can post log file is needed...
  9. #69
    Dec 2011
    Hiya everyone.
    does this work with a black hole image? i think im running BH 0.12 if that helps?
    my mate said he thinks it does and it can be installed via the control panel but im lost at how to do this because im not that clued up on these things.
    cheers
  10. #70
    Dec 2011
    Scotland
    Thanks for all info in this thread. I finally managed to get 7 day guide working.
    Just need to work on getting a view similar to pic on 1st page
    Mine isn't in the style of having the time line down it.
    Instead it looks like this
    Not sure if its just my version of crossepg or perhaps a setting that needs changed.
    I am running crossepg_0.62+git274+3e635ee-ro (Well thats what shows up in downloads via TSPanel )
    Any help much appreciated
    Mike
  11. #71
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    wot image is it
  12. #72
    Jul 2011
    Default epg
    hi
    Great just go this working.
    I am using Merlin 2 image
    Best Regards
    [I]Dreambox 800HDse,SUPERIOR DARK MOTOR METAL GEAR DiSEqC 1.2 ,Gibertini 1m Satellite Dish,FaVal TWIN LNB 0.1dB Universal Edition V2 HD SD TV
  13. #73
    Dec 2011
    Scotland
    Quote Originally Posted by smirnoff_rules View Post
    wot image is it
    image is gemini
    SIM2.01-dm800-SSL82-EN-S2-GP51
    Mike
  14. #74
    Dec 2011
    Scotland
    Any ideas anyone ??
  15. #75
    Jul 2011
    Quote Originally Posted by ukm View Post
    Any ideas anyone ??
    Hi what for ?
