Hi I have my brothers box which he has delated all key information where can you find the full atring to type back in I have the keys just the text in front and behind I need
Thanks Keith
Thanks Keith
If the keylist is deleted then restart and then put it on something like sky sports 1 and leave it on it about 10-15 minutes and it will create a new set for you. It may take less than 2 minutes but you can just check in tuxbox every so often to see if they have been created.
I have had it on for 30 mins now but still no success any ideas?
Thanks Keith
You may also have to check that you have you set AU as auto.
go to tuxbox commander
highlight camd_cfg and press 4
check that the part below has {02}
# AU
# 00 is ignored (default)
# 01 enable AU
# 02 AU Auto
A: { 02 }
go back and press red to save when prompted.
All depends what image you are using as the menus are different on some.
Try pressing the blue button and see if there is a softcamd menu, then go into it and highlight evocamd and press enter.
If its set to mgcamd then the keys will be in softcam.key in tuxbox commander
I was going to say copy them from your box to your Bro but you have a starview I am not sure if is the same.
Try this mate see if is gone to work for you:
RapidShare: Easy Filehosting
If you like my post pleas click on the little button to say thank you.
