c5 you've tested it worth to buy and where to take this product suggests
Just as DB_member says to do offline coding you need the scn code. I updated the software on 2 E classes and it asked for scn coding but since i couldn't supply the code i just left it. I have seen no problems with those cars. I think updating the software don't erase the scn coding it just wants to check the coding but if you replace the ecu then it needs the scn coding. I'm not sure about that but like i said i seen no problems with the ones i programed.
I can confirm this also. I updated S Class trasmission and although the software requested SCN code, it still updated the the control unit and repaired the problem without entering SCN.
Can any other members confirm if this is possible in other cases. Maybe it is just key progamming that wont work without SCN?
When you upgrade the ECU software, it is programmed into a flash memory . SCN Coding is contained in to eprom memory, and usually it not affected.
Hey guys,
Where do you get the software to reprogram Mercedes ECUs? SDflash?
I think most of members hire dont understand whaat is SCN coding ,, so stop wrote "where to find that software?" and for now only online SCN coding can be done.
Why are u saying that mate?There is tools like autologic that CAN do it offline,thats mean it is possible todo and others why not?Maybe some one know something more....
Smart car engineer ,
Maybe....but for sure not for 250$
Mipos...
Hmmm(nai)
Yes sure nop with this value.....
So have you ordered it and used it? Where are you from?
I'm afraid you are not talking about the same thing as others are (not exactly), if I got it right, you are referring to the pass-through option that as such is available in the US only. In Europe there is a similar option now but only for cars with the latest emissions requirements.
I believe by default we are talking about Star diagnosis tools (genuine or clones).
