read dump from dash and rewrite vin into dump.
there is an updated firmware but you cannot update the dash. also audi has no update for it. they replace the dash if it has this problem
So i tryed a lot, erase dtc, recode vin numbers in several modules.
But problem came back. So i did a lot of reading and i found the problem is in the kombi.
So i checked the vin in the combi and YES there the problem is.
But the question now is:
Can i update the kombi, with an update or other software update? there are company's in germany that do this.
my version is rb4 d37.
see attached log and screen shot from vcds.
br johnny
ok thanks for this, now im looking for tool:
i see that k+can some people use for this, ive seen it at ecutool.com
is this good tool for this?
VAG DASH COM+CAN
ore better to buy:
4-IN-1 VAG TOOL KIT
and ive seen at original com + can cost 1000 euro, maybe better to leave the clone and take this?
another thanks!!
I have the same problem with my color tacho
I want to swap from red to color, i have the pin of red, the pin of color, set mode 4 to color but i cant change in vcds the vin (i try rosstech auto learn procedure)
How you have solved?
I can write the vin direct in vag programmer?
I think vageprom can do this dash ok
I have vag eprom i dump with it
i can modify the dump of the color cluster with the data of the red? i mean vin and the other code and them write to the color with vag eprom or i need to calculate the checksum?
i have put vin and immoid on color cluster but i need also to put pin of the old cluster, i try to adapt key but dont works
