Hello everybody ,I have UEC from another car and car do not crank, I need pin for this dump.
UEC eeprom 95040 astra H 1,6 2005year
Thx for some help
Thx for some help
Hello
W0L0AHL4848123836
Pin code 8100
Bye
Hi. I need pin for this dump.UEC astra H.TX.
Hello Astra h 2005 doesnt crank or cranks for short impulses, found out that the UEC had been replaced and not programed. Need pin for reset.
Thanks in advance
Please I need PIN to adapt UEC.Thanks!
pin code 9516
Press " Thanks " button, If my post was helpful
pin code Aivaris 3435
I need help with pin code from UEC astra H.
Can you help me?
Thanks in advance
PIN CODE 9388
HI guys,
Need pin from REC Astra H 2005
PIN must be 5486
regards
BUMP:-
For us leechers who are too stupid to decode, where is the code how did you do it?
Thankssss
grail (3rd July, 2017)
Just worked it out using the other thread m8;
offset 136
copy 4 byte -> 77717B65
xor with 42454353 (BECS)
=35343836
translate to ascii=5486
if some one wants to do a list of vauxhall parts that have pins with some sample dumps and known pins - then I might do a program to get pin - change pin/vin etc when I get the chance
barho67 (14th February, 2018), bearheroes (18th September, 2014), faze (3rd February, 2020), grail (3rd July, 2017), jack11512 (21st March, 2016), jfiljak (14th December, 2015), Meat-Head (7th September, 2014), pandokrator (2nd June, 2017), pawelelectro (27th December, 2014), ph0en1x (5th August, 2015), tomxx (19th July, 2018), vertyk (8th February, 2019), ypiter (30th May, 2017)
Member Pecky who if you stalk has such an item at first he would not release it, now on his site ?80
but locked to two computers.
the rec MUST have a photo of the solder points as EEPROM on flip side, need to figer out, same with front one.
