Results 1 to 15 of 16
    Jan 2011
    from away
    Default pinout from 6LPB NOT 6LP2 FOR PEUGOET 407
    please can you help me for program this calculator 6LPB not 6LP2 .I compare between this calculators and i find the difference in shematic electronique.
    can you help me for pinout xprog for 6lpb in this picture i put it
    thanks in advance
    Jan 2011
    from away
    any help please
    really i want your help....
    rabie_m's Avatar
    Jun 2009
    morocco/sale
    not have solution
    Jan 2011
    from away
    really no solution for this calculator......
    Jan 2011
    from away
    i think nobody has the solution for this type of calculator
    Jan 2011
    from away
    any help please...
    Jan 2011
    from away
    nobody here has the solution....?
    Member lavman's Avatar
    Sydney Australia
    Hi did you check here http://www.digital-kaos.co.uk/forums...03/index2.html as I had the same 6LPB for Citroen. You need to work on front side of the ECU as per Mac Gyver's instructions it worked for me. Hope this helps
    Jan 2011
    from away
    thanks for reply and your link but i need how to program calculator 6LPB for peugeot 407 (pinout by xprog)
    thanks in advance.
    no have solution, I read this ecu with st10flasher.
    Jan 2011
    from away
    Quote Originally Posted by elosomaloso View Post
    thanks .....
    dadal's Avatar
    Aug 2015
    can someone help me please ? galetto read 576 KB,, Ktag read 512 KB,,, StFlasher read 1.4 MB ( as HEX file) and each files has different content
    wich one need I to clone this 6LPB ecu ?
  13. #13
    Dunker's Avatar
    Yorkshire
    Ktag, mpps etc read just the data area and is 512kb. Galletto reads 64k more and i think the extra 64k is near the beginning of the bin file somewhere, cant remember exactly. Hex files are txt files so will be a lot bigger. I have a job on this week to clone a 6LPC.105 and I will be trying the 512k backup 1st. I'll let you know.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  14. The Following User Says Thank You to Dunker For This Useful Post:
    dadal (23rd January, 2018)
  15. #14
    dadal's Avatar
    Aug 2015
    Thanks Dear Friend Dunker,
    I have choosen dumps of Xprog, it is also 512kb,,I wil send ecu tomorrow back to customer
    dumps from xprog and Ktag are similar
    dumps from galetto and Stflasher are similar ( when is it converted to Bin file), but still they have a small difference in content ( same bits at different adress in dump )
    problem is I cant read ecu on bench with autocom/delphi to see result,,tried by K-line and also can-bus lines
    so I will wait customer his feedback
  16. #15
    Dunker's Avatar
    Yorkshire
    I've swapped my ECU today. I just read with MPPS in boot mode and copied the 512k file to the new ECU. Everything worked ok with no fault codes.
