please can you help me for program this calculator 6LPB not 6LP2 .I compare between this calculators and i find the difference in shematic electronique.
can you help me for pinout xprog for 6lpb in this picture i put it
thanks in advance
thanks in advance
any help please
really i want your help....
not have solution
really no solution for this calculator......
i think nobody has the solution for this type of calculator
any help please...
nobody here has the solution....?
Hi did you check here http://www.digital-kaos.co.uk/forums...03/index2.html as I had the same 6LPB for Citroen. You need to work on front side of the ECU as per Mac Gyver's instructions it worked for me. Hope this helps
thanks for reply and your link but i need how to program calculator 6LPB for peugeot 407 (pinout by xprog)
thanks in advance.
no have solution, I read this ecu with st10flasher.
can someone help me please ? galetto read 576 KB,, Ktag read 512 KB,,, StFlasher read 1.4 MB ( as HEX file) and each files has different content
wich one need I to clone this 6LPB ecu ?
Ktag, mpps etc read just the data area and is 512kb. Galletto reads 64k more and i think the extra 64k is near the beginning of the bin file somewhere, cant remember exactly. Hex files are txt files so will be a lot bigger. I have a job on this week to clone a 6LPC.105 and I will be trying the 512k backup 1st. I'll let you know.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
dadal (23rd January, 2018)
Thanks Dear Friend Dunker,
I have choosen dumps of Xprog, it is also 512kb,,I wil send ecu tomorrow back to customer
dumps from xprog and Ktag are similar
dumps from galetto and Stflasher are similar ( when is it converted to Bin file), but still they have a small difference in content ( same bits at different adress in dump )
problem is I cant read ecu on bench with autocom/delphi to see result,,tried by K-line and also can-bus lines
so I will wait customer his feedback
I've swapped my ECU today. I just read with MPPS in boot mode and copied the 512k file to the new ECU. Everything worked ok with no fault codes.
