MARIKO (7th January, 2020)
Dear mates,
I meet a serious problem on a P206 1.4 HDI vehicle with EDC16C3 ECU: on the athmospheric pressure reading hole the water enters in the ECU and destroy the ECU (I cleaning the board, but I can't read the ECU via BDM, allways display communication error or power supply drop), I dismantle completly the ECU and found a lot of dirty on the SPI eeprom (95160). I desoldered the eeprom and the memory dump is fully 0! So, I can't clone the defective ECU...
The customer have another ECU, but I don't know what is the best solution to resolve the car.
If enough to remove the IMMO from the ECU dump, please remove it, if not enough please describe the procedure. I have acces only for DEC diadnostic equipment (is veri good in BSI coding for Peugeot, but I can't acces "original" PSA diagnostics).
Thanks in advance!
Best regards,
Feri
maher1800 (18th January, 2020)
Hi Sandu,
thanks a lot, tomorow I will test on the car and report the result!
Best regards,
Feri
hi, i have similar probleme with ecu 206 1.4 hdi edc16c3 0281010707
this is my original dump
please can someone help me with off
MAYQUAD (28th June, 2014)
hi lupu,
can you please help me with off for 307 1,4 hdi EDC16C3 47
0281 010 390 here is my ori
thanks in advance
Please don't be discouraged, Nothing comes easy in life
The best way is to desolder / remove flash 29BL802CB and 95160 from destroyed ECU and solder it to new ECU.
Plug and play!
Did this several times. 100% working, of course ECU must be same (bosch numbers)
your off file
pass pm but you must delete some message from your inbox
lichir (11th August, 2019)
Here i have a 206 ecu i need immo off please
manel19 (29th October, 2020)
Hi , can you immo-off my dump please ?
thank you
All of my posts are for educational purposes only.
If this was helpful to you, please press THANKS
