Page 2 of 8 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 107
  1. #16
    Jul 2011
    Quote Originally Posted by AbsoluteFire View Post
    This is ASA8.4
    Thank you for the files. Could you please give me the PW?
  2. #17
    Jul 2011
    could you pls give me password for the files....BIG THX
  3. #18
    Jul 2011
    i've a problem logging into a asa 5505 of my client. asdm always writes "device does not have appropriate device manager version installed, only supporting 5.0 or higher".
    can anyone help?
  4. #19
    Aug 2011
    Thnks for the files. Do you have CME software for Integrated service routers?
  5. #20
    Aug 2011
    Is it possible to install the asdm direct from a file to laptop without downloading it from the router first.
  6. #21
    Jul 2011
    Can someone give me the PW for the files?
    Get no reply from AbsoluteFire.
  7. #22
    Same for me....can't get any reply from AbsoluteFire any help on the password is highly appreciated
  8. #23
    Still can't get any help on this!!, however I found this useful so I'll share it with you!!
    Index of /work/asa
    If it was useful for you don't forget the thanks button :-)
  9. #24
    Aug 2011
    I'm new here. Can I upgrade to 8.4 from 7.2? will there be any issue if I do that?
    Thanks.
  10. #25
    Jul 2011
    If you want to upgrade your ASA from 7.x to 8.3 or later, you have to migrate some settings (like NAT) in your config.
    For details look here:
    Cisco ASA 5500 Migration to Version 8.3 and Later [Cisco ASA 5500 Series Adaptive Security Appliances] - Cisco Systems
    Additional you maybe have to upgrade the DRAM. Cisco has new requirements since 8.3 (see the release notes)
  11. #26
    Sep 2011
    Can I use this version on GNS3?
  12. #27
    Sep 2011
    Quote Originally Posted by ashkan View Post
    Unlikely that will work.
  13. #28
    Sep 2011
    Sorry it may, I'll try it and let you know shortly.
  14. #29
    Sep 2011
    Quote Originally Posted by dpsguard View Post
    Anyone knows the difference between the Redundant interfaces and Etherchannel functionality in the new ASA code? Is it same? Can I use etherchannel across the two redundant ASa to connect to two 3750s in a stack?
    Thanks so much.
    It is not the same, the redundant option is simply for interface failover. Yes you can use etherchannel from the ASA to cross stack switches.
    Here is the config for the switch side: Cross-Stack EtherChannel on a Catalyst 3750 Switch Configuration Example - Cisco Systems
  15. #30
    Sep 2011
    Quote Originally Posted by TomCatXY View Post
    can anyone help?
    You need to update ASDM to a version compatible with you ASA Software version.
