Page 7 of 7 FirstFirst ... 234567
Results 91 to 102 of 102
  1. #91
    Member anthonycorsi's Avatar
    venezuela
    hi someone could share blueprint or some kind of identification of internal parts in ddec 3/4 ecu and where i can find replacement parts thanks
  2. #92
    Member carlosramospoma's Avatar
    Oct 2010
    quito ecuador
    Default Dieselhawk
    Quote Originally Posted by Dieselhawk View Post
    Sure, this is the replacement
    Made under license for Sony by Varta ( Germany ) 3 volt lithium battery 5 year life Part number 0708 , 8 year life Part number 0905 - ask for plastic holder.
    You need to solder it in so it's a bit fiddly.
    good afternoon friend you can help me with an address or link to the ecm lithium battery decc4 Made under license for Sony by Varta (Germany) 3-volt lithium battery 5 year lif
  3. #93
    Dec 2010
    el salvador
    when a have the code low voltage detected in the sensor output i change this 4.5 to 0.00v and i solved the problem in the ecm.i found this parameter in ****og input
  4. #94
    Dec 2010
    el salvador
    the ecm ddec3 have 3 memory
  5. #95
    Dec 2010
    el salvador
    to solve the fault code 53 reprogram with ddrs if not turn off the fault code change the memory
  6. #96
    Aug 2016
    Quote Originally Posted by sptecnico82 View Post
    You are right.... but in my country there are 4 DD for each Cummins.... thats why I see many DD damaged.
    Just for introduce a topic... what is the function of each 32 pins chip that store the program?. There are 2 that say "FLASH", 1 with a sticker and another that I dont remember what says.
    I suspect that the 2 that say "FLASH" are the volatile memory. It is?
    I hope somebody can know the answer.
    Yes it is prom memory, and don't peel off that sticker. If it's what I think you'll likely at the least corrupt the eprom or erase it all together. I can't tell you what the chips do. Seems to be a well guarded secret what makes these 20 year old dinosaurs tick. It is rather amazing just how well they work considering what was available 20+ years ago.
  7. #97
    Feb 2013
    Quote Originally Posted by SaMirakle View Post
    Does anybody have any .prg files for any of the 60 series? THANKS!
    i have all
  8. #98
    Nov 2015
    Hello . I have a problem with ddec 4 308 ECU . Burned 2 low Ohm resistance on the 12V supply is shorted on the controller TLE4270G , between 5 foot regulator and ground resistance of 180 ohms .That is, closes the 5 volt power supply . Please tell me what it could be shorting .
  9. #99
    Nov 2015
    IMG_20160622_151524.jpgYes, and even burned capacitor near TLE4270G
  10. #100
    Oct 2016
    Can anyone share with me schematics for DDEC 3/4 ecm if available? Or where I can look to possibly find them?
    Thanks.
  11. #101
    Aug 2010
    share me dump DDecIV memory AT28C256 vs AM29F400 please
  12. #102
    Sep 2018
    Is there Somebody can share picture or components around DDEC V Battery because all elements are gone and im trying to rebuild one ddec V.
    I appreciate !
