Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 102
    Member sptecnico82's Avatar
    Sep 2010
    Sonsonate, SV
    Exclamation DDEC III and IV repair tips.
    OK... Cummins haves its own thread about repairing... why don't we start a thread about repairing Detroit Diesel ECMs too?
    There are many people who knows many tricks.... we can share about that.
    Share and use the THANKS button and from time to time somebody will help.
    PD. Use the REPUTATION button too.
  2. The Following 2 Users Say Thank You to sptecnico82 For This Useful Post:
    ernesto123 (23rd October, 2017), mang5087 (13th October, 2013)
  3. #2
    DK Veteran ddmech's Avatar
    Feb 2011
    middle of nowhere usa
    Thats because cummins has about 60% failure rate.Ddec probably 5%.
    Sep 2010
    Sonsonate, SV
    Lightbulb
    Quote Originally Posted by ddmech View Post
    You are right.... but in my country there are 4 DD for each Cummins.... thats why I see many DD damaged.
    Just for introduce a topic... what is the function of each 32 pins chip that store the program?. There are 2 that say "FLASH", 1 with a sticker and another that I dont remember what says.
    I suspect that the 2 that say "FLASH" are the volatile memory. It is?
    I hope somebody can know the answer.
    Default Detroit DDEC IV Timing
    anyone know anything about the timing on a 14LTR DDEC IV was told if you advance it up 1 tooth gives 30-40 more HP at the wheels
    Sep 2010
    Sonsonate, SV
    Quote Originally Posted by Matrans View Post
    I dont belive it can be done that way.... maybe with DCT is better.
    I saw a engine with one tooth timing of mistake and it cant stay run.
    Have already used DCT but always looking for more.Was told of a Mechanic that works for Detroit he has done it and dyno report before was 580hp after was 616hp at the wheels.
    Sep 2010
    Sonsonate, SV
    Cool
    Very interesting.... if we can know more details... maybe somebody can try with an engine..
    Feb 2011
    we advance timing frequently on ddec iv.You check timing with gauges to find present timing.One tooth will advance app .40 injector lift.Some motors will stand it and some wont.YOU MUST CHECK TIMING FIRST WITH GAUGES.VERY CRITICAL THIS BE DONE.If not disaster is posible,he,he,he!
  10. #9
    Sep 2010
    Sonsonate, SV
    Thumbs up
    Can you make a more detailed explanation of the process?. I am not a mechanic.
  11. #10
    Top Poster torqueman's Avatar
    Canada
    I don't think that chnaging one gear teeth will chnage hp in any case.Done tones of inframe and never seen or heard if anybody have done one teeth advanced and engine still running normal.
    In my case by change i have done one teeth wrong while installing cam shaft on 04 egr dd engine and after everyhting done, Started engine, that runs like a shit,smoke everywhere,vey hard to start.
    These are not mechanical engine that you can advance or retard engine timing and getting more power.
    I don; t agree with that.
  12. #11
    Yes you are right,we checked timing and it was at 275 if advanced it would take it up over 300 to much.A bloke told me Detroit specs are (254-299) Was told if it was under 260 no problem but not at 275.
  13. #12
    Feb 2011
    275 is low average.You can go .05 to .10 over specs without damage to engine but you must watch ex temp in warmer weather.Will run like scalded dog!
  14. #13
    Sep 2010
    search on forums for detroit power service literature (psl) i believe this has the entire series 60 manual in it. it will explain exactly how to check your cam timing
  15. #14
    Question for you Detroit guys : have a 1999 ddec III or IV engine i think its III but for some reason the cooling fan will not shut off I plug into the thing and it says aux switch is grounded buy there is no switch in the cab so what exactly does that mean ? and where can i find the switch to test it ? thank you
  16. #15
    Sep 2010
    if you have an ac pressure switch disconnected or faulty it will make the fan run. i forget how it's wired but the systam thinks that the ac pressure is high so it runs the fan to try to bring pressure down by cooling the condenser
