CAT Factory Passowrd - Page 3
Page 3 of 46 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 683
  1. #31
    Junior Member mmrj's Avatar
    Dec 2010
    right here
    I have a break out harness for both 70 pin and 40 pin i have never flashed the old 40 pin style only the 70 pin I am wondering if you can post the wash files on here for the 40 and 70 pin ecm. Also does the old style ecm have all the same fls/fts, interlock etc or does it have different things to set ? thank you for you help
    And no there not just labled "wash" , not that easy to find..
    http://www.digital-kaos.co.uk/forums...h-file-216205/
  2. #32
    Aug 2010
    I recently acquired a factory password keygen 2010A version I have been having difficulty genrating passwords I followed the instructions that came with the keygen. How do I transfer the information from ET to the keygen? I am not familiar with it. I have been using ET for awhile and never had to clear events that reqired factory passwords until now, If anyone can help me with some more details thanks
  3. #33
    Dec 2010
    right here
    When you are changing anything that requires Factory passwords, Go to the screen where you enter your passwords, at the bottom it says save to file... click it... go to your pw gen, on the right side you will see a icon of an opening folder.. click it ... find the file you just saved from et password screen .. open it .. it will automacticly load into your pw gen... on the right side below the folder icon you will find the icon that looks like the keys .... click it ..... you will get a green light and your passwords will appear at the bottom of the right side of pw gen..... IF you dont get any passwords and the light comes on red ... your generator is no good or installed wrong..
  4. #34
    Dec 2010
    right here
    There is no differance in proceedure between doing a 40 or a 70 pin flash unless.... the 40 pin has a low nox file, then you will have a high interlock ..
    ALWAYS copy configuration first before flash on any ecm, (just in case) ... If when you expand all in your configuration it is labled something like "475 low nox" you will have a high interlock. This only aplies to older 40 pin ecms.. No problems with 70.. Be carefull when using a "wash" file it will make your ecm like new. THere are pw gen's that do high interlock if you want to spend the $$$
    127 fls
    0 fts is wide open "so they say"
  5. #35
    Member frank antonio ruiz de la's Avatar
    Jan 2011
    mexico
    my friends need the paswoords for caterpillar, thank you very much greetings.
    C:\Users\Public\Documents\WRPTXXXXXX...1201125705.xml
  6. #36
    Jan 2011
    mexico
    hello friends dk, someone could generate these keys, greetings and thank you very much
  7. #37
    Aug 2011
    hi need CAT factory password kegen to work on CAT ET 2011A , does anyone has any idea from where i can get one ?
    for now i need a factory passowrd for reason
    the file is attached and i need urgently, any helping hands ??
    thank you
    Service Tool Serial Number: ET061440-6-TF
    Engine Serial Number: 66601121-JZ
    ECM Serial Number: 10066141MB-SC
    Total Tattletale: 2071
    Reason: 3
    Diagnostic Clock: 3608 hours
  8. #38
    Jul 2011
    Indonesian
    Quote Originally Posted by mehmetali View Post
    thank you
    Reason: 3
    AH5X=3CLSM
    8BTF44M=Q2
  9. #39
    North America
    Default password for CAT ET
    HY FRIENDS
    I need pass for CAT ET 2010A V1 my code is
    4F98 2B9F 4753 3D1C 27EF DE8D
    Thanks in advance
  10. #40
    password for CAT ET
    HY FRIENDS
    Thanks in advance
    your key
    9B7F 7CD7 6359 7DFB 3337 D913 36
    ENJOY
  11. #41
    Top Poster whisky2510's Avatar
    Default hi
    Quote Originally Posted by farhad.websman View Post
    hi,i get car soft fpkg,but generated fp1,fp2 does not accepted by ecm,can you help me?
    i have the same problem help please need a good fact pass and with et work please thanks in advance
  12. #42
    Quote Originally Posted by bnb View Post
    When you are in CAT ET you will go into WinFlash - it is an icon on the top of the screen that looks like an ecm with an arrow going into it. Once you are in WinFlash, you will choose a file using the browse button. There are flash file disks or you can get files on here for the application you are looking for. Once you choose the file then you click on the begin flash button. A status bar will come up telling you that the flash has begun and will move from 0% to 100%. Once the flash is complete a window will pop up asking what you want to do next. Choose RETURN TO CAT ET. It will then reload your information from the ecm. You MUST program the personality module (just above the FLS and FTS setting). Just choose to program it, the program will ask you if you are sure, choose yes. This is where you will need to use the keygen to make the password. If your keygen fails to make the right password, then you are stuck at that point. This is why you will have to flash it with a wash file first, then with the desired file that will get you past the three didget interlock code problem. It is done the same as described above.
    Once you have completed the flash, always check your file by starting the truck and checking throttle response. You can flash an ecm and the truck will start and run, but with out the personality module being programed properly, you will have a dead pedal.
    Any time you flash an ecm you should use a break out harness and go direct to the ecm, not through the data port as you can end up with corrupt files. I have had some older trucks where the flash would not go through the data port and would reject or freeze up half way through. Also it is much faster to use a break out harness.
    Hope that answers your questions
    when program the personality module the parameters enter auto or me write this parameter ? Since know that parameter to enter or et select it auto? thanks in advance this is a great help thank you
  13. #43
    DK Veteran rudamie's Avatar
    Digital Kaos
    Quote Originally Posted by whisky2510 View Post
    whisky2510,
    Try these keys see if they work for you.
    Pass #1. FH=7LR11R4
    Pass #2. =9Y%3A5MPP
    Don't forget to hit the thanks button......!
  14. #44
    thanks a lot with what et version work it?
    thanks in advance
  15. #45
    Aug 2011
    h***305; ;
    thank you
    Engine Serial Number: JKH01743-P1
    ECM Serial Number: 05686863MB-TK
    Total Tattletale: 1
    Reason: 3
    Diagnostic Clock: 4200 hours
