petrol or diesel
petrol or diesel
Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable screw you nag3
its petrol
ok, th1st thing is the barrey which you have done, when was the last time it was serviced? work your way back from the battery. check the leads and plugs. are you getting a spark?
is fuel actually getting to the engine? check the pump works, give it a tap with a hammer.
see how that goes
have you check
1 temperature sensor
2 fuel pressure reg + hose
3 it just might be maninfold pre heater relay its on the left side wing by power steering bottle
4 if it is eccs system on ls gs gsx 1990 on you can check the redLED light on th ecu the lamp should flashmore than 5 time during a 10second periode. if out discooect temp sensor and bridge with a 2.5k ohms resistor run engine 2000/3000 rpm several time re check LED on ecu remove resister and refit plug you have just reset the fule system and the mpg of the car
..i have E.S.M (elettronic service manual) for all nissan...pm me
THANKS dctyper
i need service manual for nissan P12
