Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 47
  1. #16
    unu's Avatar
    Oct 2010
    EUROPE
    Quote Originally Posted by meteor80 View Post
    Hello.
    I have also Vcc pin overloaded.
    What is the label (voltage) of Zener diodes?
    i suppose it must be 5V6 zener diodes
  2. #17
    meteor80's Avatar
    Yes, You are right.
    But I don't know how to check Voltage during programming, because when I push "program" button it shows Vcc overloaded and no Voltage on selected pins.
    Work is a primitive way to spend Your free time.
    F.Kiepski.
  3. #18
    Holtek's Avatar
    No! The correct value of the Zener diodes is 5.1 V.
    meteor80 - the correct voltage should appear for a short time. Connect the multimeter, and then press the "program"
  4. #19
    If Xprog-m still follows its predecessor, Xprog, design concept, all those zener diodes are 5.6v
  5. #20
    Hi i have same problem with original xprogm trying to read 9s12 in cas3 and ews4 at the moment, so i ordered tantalum capacitors, but did you guys who had the problem fixed it by changing them capacitors or not ?
    Also what cause the capacitors to get damaged ?
    locks85
  6. #21
    DK Veteran andrym3's Avatar
    first check these components
    connection pin 9 (PE7) of ATMEGA64, ddtc143EVA, IRF7316 and LM317L
  7. #22
    Hi, when you say check them what do i need to do exactly ?
    I am just a locksmith using xprog-m you see .
    Thanks in advance
    locks85
  8. #23
    You must do the test during reading or writing(with or without MCU,EEP)
    5V - pin2,3,6,7 LM317l
    0V - collector of DDTC143EVA
    12V - pin5,6 IRF7316
  9. #24
    Can you please mark the points on the picture ? i cannot find out what do you mean, and forgive me for that .
    locks85
  10. #25
    pins in lm317 maximum voltage 2.9
    pins in IRF7316 MAXIMUM 10 V
    Lokcs85
  11. #26
    Default VCC PIN OVERLOADED
    I replaced LM317 and IRF7316 BUT STILL THE SAME PROBLEM
    Any more ideas ?
    locks85
  12. #27
    CHECK AND REPORT
  13. The Following 2 Users Say Thank You to andrym3 For This Useful Post:
    BimmerGT1 (17th July, 2013), haingoben (23rd January, 2018)
  14. #28
    Jun 2009
    the yellow capacitors has shortcircuit. remove them and check them with a multimeter . in ohms you will see shortcircuit.
    be carefully they have + and - . take a picture how you have remove them .
    i have fix mine xprogm a lot of times and i am sure that know is better than original .
    some times if i use chinese usb cable by xprogm not works . so i have found the appropiate to do my job.try different cable.
  15. #29
    Jun 2009
    Check to see if it works on another usb computer.
  16. #30
    maaxxyy's Avatar
    North Pole
    had the exact same problem with reading hc912, recently moved my gear into a different room. so i used a different usb lead (not the original i was using), binned the used and got the original one back. All working well now!
