Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
  1. #31
    Senior Member cdex's Avatar
    Oct 2012
    somewhere beyond the moon
    solved problem with vcc overload
  2. #32
    autocargo's Avatar
    Quote Originally Posted by cdex View Post
    Can you tell us more? Thanks.
  3. #33
    Oct 2012
    i had same problem and solve it with capacitor change
  4. The Following User Says Thank You to cdex For This Useful Post:
    autocargo (31st March, 2016)
  5. #34
    autocargo's Avatar
    Have you changed them all? Same value? Electrolytic or tantalum ones? Could you post a picture?
  6. #35
    Holtek's Avatar
    Replace six capacitors. Show in the picture.
  7. The Following 2 Users Say Thank You to Holtek For This Useful Post:
    autocargo (31st March, 2016), valdirld (2nd May, 2016)
  8. #36
    Sep 2016
    I have similary problem but I also change the MCU yesterday
  9. #37
    PierreTheron's Avatar
    Centurion,South Africa
    Capacitor change should do it if i read correctly
  10. #38
    hello to all
    thank you for sharing
    i have two xprog i need to programme Motorola MCU MC68HC11E9 4E28B
    i see this vcc pin overloaded
    xprog-m and xprogbox same probleme
    any idea
    best regards
  11. #39
    dragoshu's Avatar
    Aug 2016
    Dacia
    Quote Originally Posted by abdelamjid View Post
    hello to all
    any idea
    best regards
    You must use original cable ,otherwise become a mash!!!
    regards
    If I help you dont forget to push thanks button
  12. #40
    Quote Originally Posted by andrym3 View Post
    CHECK AND REPORT
    Why was the diode removed and where other soldered? Can someone tell me.
  13. #41
    Jul 2017
    Hi to all friends. I have xprog m 5.5.1 . Always was good. But now when i try read tms i got low voltage error. With serial eeprom everythin good. Any solution?
  14. #42
    External pover 15v ?
  15. #43
    Jul 2017
    Always was good with 12 v power. Now i just buy 15v power and now reads egain. Thanks
  16. #44
    Top Poster Kalectro's Avatar
    Dec 2016
    I had the same problem while reading an hc11c1 in-circuit. It was a bad selected pindata connection.
  17. #45
    you had them on opposite direction, or you had them in short circuit state?
    HEX FW 48 available
    Chiptuning solutions - dyno proven
  18. The Following User Says Thank You to mamanacusa For This Useful Post:
    locksmithpro (8th July, 2022)
