Page 1 of 4 1234 LastLast
Results 1 to 15 of 47
    Senior Member el_futte's Avatar
    denmark
    Default xprog m vcc pin overloaded ?
    hello there i try to read out a motorola hc912d60 but i get this erroer every time.
    vcc pin overloaded tjek vcc pin connection.
    any idea ??
    xprog-m v 5.0
    May 2009
    hi
    I have the same problem
    there are any solution for this
    vcc pin overloader
    any idea is very apreciate
    many thanks for all in te advance
    regards
    Holtek's Avatar
    Is the processor is desoldered? XPROG-m Output-VCC supplies only the CPU? and aslo other components? What happens when the programmable processor is powered from external power supply?
    May 2009
    hello
    thanks for your reply but
    is the same problem conections external power or usb
    the same error
    no desolder nothing
    regards
    Holtek's Avatar
    Lift the pins that connect to the programmer. Connect the external power supply (13-15VDC) to XPROG-m.
    Jun 2009
    1:check other eeprom if working
    2 if yes you have a damage eeprom and not xprog
    if no
    3 open the unit and check by your hand which component get hot.
    4 you will find a yellow capacitor and desolder it
    5 check knoe if xprog read the memory
    6 replace the capacitor .
    7 NEVER CONNECT THE CLONE XPROG WITH POWER SUPPLY .
    Holtek's Avatar
    Quote Originally Posted by gadroulll View Post
    Why not? Explain! When the USB output current is too small, it is necessary to connect an external power supply.
    May 2009
    Quote Originally Posted by Holtek View Post
    hi
    which pins are need lifts to prove?
    I don?t undersstand
    May 2009
    if no
    but the eeprom is good, the same problem is whit mcus
    what capacitor?
    please paint in the photo
    many thanks in the advance
    Holtek's Avatar
    Check the eight diodes Zener. Do not have short circuit?
    Check the voltage marked on the picture.
    May 2009
    hi
    Holtek many thanks for your big big big help
    the problem is a condenser , see photo is bad direccion solder.
    but the programmer works well 1 year whit condenser solder in this direccion. electronics mysterius
    NOw my programmer not read good in hc05 and 9s12 , and not read tms botloader error
    read good but sometimes verify error.
    what is the new problem?
    many thaks in the advance
    regards
    Holtek's Avatar
    Wrongly soldered capacitor hehe Replace it with a new one. The best solution to replace all tantalum capacitors for electrolytic capacitors.
    Have you tried several times to read the TMS? You tried to read several TMS?
  13. #13
    May 2009
    hi
    what ref is capacitors electrolitic?
    change all capacitors?
    I read tms immo opel and vag and read good whit usb and power suply 12v in 2 programmers
    regards
  14. #14
    Holtek's Avatar
    Do not have to replace all. Replace the most important, marked in the picture.
  15. #15
    meteor80's Avatar
    Hello.
    I have also Vcc pin overloaded.
    What is the label (voltage) of Zener diodes?
    Work is a primitive way to spend Your free time.
    F.Kiepski.
