Page 2 of 8 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 120
  1. #16
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Try making the Recordings folder on the C: drive, not sure if you can mount to an external drive.
    Does your external drive have an ethernet connection? So is it connected to your dreambox or router? If it's in a NAS enclosure then you need to select SMBFS as the filesystem and not CIFS, this is for a shared folder on a PC.
    Get Digital Kaos on your Apple or Android device with Tapatalk
  2. #17
    V.I.P. Member westkill's Avatar
    May 2008
    i have mine mounted to a usb drive encloser drive as it shows up in
    start>computer as one of the hard disk drives
    so in that drive create a folder as recordings and right click on it and share
    then i used the web interface to mount it as a cifs
    settings add your own ip address in pic 1
  3. #18
    Top Poster Sig-gotyouth's Avatar
    Jul 2008
    awesome. thanks weskill will try it once I get home... otherwise I might just ask someone to do it for me by connecting with remote assistance or something
    <--Sig-gotyouth added 130 Minutes and 11 Seconds later...-->
    ok followed that screen and it seems to be reading the drive now.. but it tells me:
    Record stopped due to full harddisk. Delete some recordings and try again.
    so is there anything else I have to do? I seem to have 253GB free accoring to the drive under my computer
  4. #19
    May 2008
    is it showing the drive mounted, when you press the mount button on the web interface then says inaccessable storage
  5. #20
    Jul 2008
    no its still red... but unlike the other mounts that say 0 the one i set up sais 1 under auto
    I'll get the info on my box if that helps?
    do I need to restart the dreambox?
    westkill.. could u tell me the settings you have on your dreambox aswell...
  6. #21
    May 2008
    heres a screen shot of mine 3rd up from the bottom
  7. #22
    May 2008
    try restarting the usb drive, click the interface off, restart the dreambox
    restart the interface and try mounting it again
    if mounted you should see the size of the drive above the help button
  8. #23
    Jul 2008
    Im not sure what Im doing wrong... I seem to have the same setup as you but I just have the dredded red x's. tried it sadly it didnt work... is there any chance i could trust you with my ip and you could enter my net interface to sort it for me?
  9. #24
    May 2008
    mines stopped working as well now
  10. #25
    Jul 2008
    haha... sorry . yeh I really dont understand what I done wrong... I sent ya a pm.. if you can help me, I'll then post in here what went wrong and what was the solution for fellow noobs
  11. #26
    May 2008
    is there a reason why you canot do it on the main drive of your pc or are you using a laptop with not much memory
    just trying to see if your box is networked ok
    i got you pm
  12. #27
    Jul 2008
    main drive wasnt working thats why I tried the external... thats it really.. and my desktop isnt short of memory... Im running through a router.. maybe theres another port besides 8080 and 80 that I need to open?
  13. #28
    May 2008
    so what drive are you running your os off if main drive not working if you dont mind me asking
  14. #29
    Jul 2008
    haha nooo. I mean I tried my main c: drive to get recording working but it didnt work so I tried the external drive option... seriousley it would be so much quicker through msn... but wwhatever haha
  15. #30
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    If you're about tomorrow afternoon I'll hop on MSN and we'll try and sort it.
