Page 3 of 8 FirstFirst 12345678 LastLast
Results 31 to 45 of 120
  1. #31
    Top Poster Sig-gotyouth's Avatar
    Jul 2008
    figured it haha... might wanna add to the guide to restart the dreambox to confirm settings. it seems thats all I had to do. found out by accident that recording now runs absolutley fine
    PSN = Sig-gotyouth
  2. #32
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    I've never needed to restart the dreambox to get it to work but I'll add it nevertheless, thanks.
    And glad you finally got it working, well done!
    Get Digital Kaos on your Apple or Android device with Tapatalk
  3. #33
    Jul 2008
    I also stumbled across another way to record just incase it turned out I couldnt get your method to work.. its by using a programme called n-grab. I'll upload a guide a found at another site...
    also... how do I direct record. seems on the dkv1 img the option doesnt come under the blue button
    PSN = Sig-gotyouth
  4. #34
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    I've edited that part of the guide as well. Although it does say that every image may be different.
    For the DK V1 image, as described in the feedback thead , it's...
    Green - SubServices for satellite viewing, i.e. Premiere Sport Portal. Also if you hold it down for more than 3 secs it shows the DVR controls for recording.
  5. #35
    V.I.P. Member dctyper's Avatar
    Jun 2008
    ok followed the guide to the letter but i get a failed message
    ive done:
    IP : 192.168.1.xxx CIFS
    Dir: daves dream
    LocalDir: /hdd/movie
    options: rw.soft.udp.nolock
    extra: nolock.rsize=8192.wrsize=8192
    user:
    pass:
    but no joy!
    my shared folder is in my shared documents on the c: drive
    any ideas
  6. #36
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Try giving the directory only one word, i.e. movies.
    The user: section should be the username of the account you use on your PC. If your account doesn't need a password, leave it blank.
  7. #37
    Jul 2008
    also after try rebooting your dreambox
    PSN = Sig-gotyouth
  8. #38
    Jun 2008
    i didnt put the user in, didnt think i needed to as im the only one. thanks
  9. #39
    Aug 2008
    Hi, I've just installed the DK image & things seem to be going well so far, but I'm having a problem with setting up recording.
    When trying to create the mount, I get to local dir, press OK to set it & get a file explorer. I can browse to /hdd, which shows 1 directory called movie and I have the green button listed as save. If I go into movie, the option to save with green disappears. So, I can only set the local dir to /hdd, it won't change to /hdd/movie as it refuses to save when I'm in there.
    I thought if there was something in movie, I'd be OK but I can't create a dir in telnet as it tells me it's a read-only filesystem.
    I guess this gets created in a text config somewhere? If I could edit that, I could just change /hdd to /hdd/movie.
    Just to add to this, I managed to get it mounted using Curious123's suggestion of the web interface here:
    recording help
    When I go into the mount menu on the Dreambox though, I can't see this mount. To mount the PC shared drive, I have to go to the PC, fire up the web interface & mount it that way, so this is only a temporary solution. The web interface doesn't see my failed settings either, even though I saved them.
  10. #40
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    Default all mounted but cant find start recording
    shared ok and mounted. Show i have over 100gig free 72 hours recording but i cant find the start record feature. I am using dk v1.1
    Any help guys?
  11. #41
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Quote Originally Posted by cgscott View Post
    Any help guys?
    http://www.digital-kaos.co.uk/forums...ecord-pc-6667/
  12. #42
    Oct 2008
    Thanks a lot
  13. #43
    Sep 2008
    Question Recording to hard disk on PC
    I have set up to record from my DM 500C to my PC. After some trial and error I finally got it work. Problem now is that the recordings are very poor (5 secs and then the recording sticks for 5 secs and then continues). I've read that that the DM 500C's processor is relatively weak and therefore may contribute to the problem. Any ideas to improve the recording quality?
    DM 500C
    Gemini 4.2
    vlc media player 0.94
    Streaming to the PC works no problem.
  14. #44
    Jul 2008
    cmd
    Cant see what the problem is.
    I use dk image and the recording is fnie.
    I have recorded for up to 2 hours without any hassle.
    What cam you use?
    I use evocam
  15. #45
    Sep 2008
    I am using
    MgCamd 1.30a/New CS 1.60
    if that makes any sense.
