Page 1 of 16 12345611 ... LastLast
Results 1 to 15 of 229
    morocco/fbs
    Default IAW 59F 5AF 5SF DECODER
    i recieve now my new tool fro IAW 59F 5AF 5SF DECODER from italia
    hw is not same as kwp2000 it is deffirent
    i test it on 59f m3 hw103 read write verry fast
    i post all i have just for DK members
    This interface operates on ECU 59F above and below 100 and 5SF, enables the riverginazione, scodifica the total becomes m3 m5 m7 m9, operates ECU mounted on a Ducati.
    It does not require opening the unit, you can work in peace and quiet, just a simple clik to transform, scodificate completely, and erase mistakes riverginare DTC stored previously.
    Very useful tool for tracking down those damaged units (default classic 2-cylinder) and carry out repair and resale "59F reclamation" of these highly sought ECU.
    Models Supported / Supported Models:
    59FM2
    59FM3
    59FM5
    59FM7
    59FM9
    5AM DUCATI
    5AFP3
    5AFP4
    59M
    5SF
    LIST OF FUNCTIONS SUPPORTED
    DECODE 59F
    SCODIFICA PARTIAL / TOTAL ABOVE HW-100 WITHOUT BOOT
    SCODIFICA PARTIAL / TOTAL 100 HW UNDER NO BOOT
    CHANGE SW M5 M3 5AF 5AM (Ducati) 100 ECC HW ABOVE WITHOUT BOOT
    FLASH WRITE ABOVE HW 100 WITHOUT BOOT
    5SF (HIGH POINT)
    SCODIFICA PARTIAL BOOT MODE
    READING FLASH BOOT MODE
    WRITE BOOT FLASH MODE
    EASY TO INSTALL AND CONNECT TO ECU WITH 4-WIRE
    5SF (NEW 500 AND NEW FIESTA)
  2. The Following 30 Users Say Thank You to jokersat For This Useful Post:
    Abdo Abdelatif (29th October, 2022), amir jafari (7th March, 2016), araby80 (21st December, 2014), Auto Sousa (19th April, 2024), ayllon308 (5th December, 2018), dada alla (25th September, 2022), ddtech1 (23rd August, 2014), electronicdeivi (15th March, 2024), esobrino9 (21st February, 2023), FANOBD (10th December, 2013), fuktak (23rd December, 2015), galfio (14th December, 2014), garagetech (27th January, 2015), ichkata (6th July, 2015), Jacob6969 (2nd June, 2022), lirinikut (16th January, 2023), mcday (20th December, 2019), mimodiag (12th October, 2015), mohamedkey (10th October, 2014), nelsoncaseiro (5th October, 2013), niwat_spp (29th November, 2014), notoetannoto (5th February, 2015), otojm (18th September, 2014), pandokrator (8th August, 2013), puntoPat (13th March, 2015), redful (27th October, 2018), robert1966 (31st March, 2015), superehj (19th January, 2023), VORTEXANDREJ (7th January, 2016)
  3. #2
    Aug 2010
    maroc_spain
    Default IAW 59F 5AF 5SF DECODIFICADOR
    hello please can you tell me which interface you use this program
    which interface does work with this program?
    Oct 2008
    Whwre did you bought it )
    Hollywood
    đđĐđß$đĐßđßđßđđääđłldkf>>;*;ßßߤߤ;>>;>ßߤ]$ß$÷÷×ßß]¤¤¤]ß$$[ß[¤ĐĐß[ß...
    morocco/fbs
    original interface from italia
    see here IAW 59F
    this interface is different
    Hollywood
    Jan 2011
    Quote Originally Posted by jokersat View Post
    see here IAW 59F
    Mate is there a way we can see the interface from inside?
  10. #9
    racin-snake's Avatar
    Jun 2009
    not just interface but a pin out of the connector mate if its possible ?
    maybe the wiring to the feed plus after ign and feed to switch
    seems a bit of contesion over earthing too either earth to ecu body or to the pin on plug 1
    all info appreciated
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  11. #10
    morocco/fbs
    i confirm for all DK
    i test this interface on IAW59F M3 Today it work ok verry good no need open ecu
    test Virgin = good tested on Car Punto work 100/100
    test Immo Off = Good tested on Car Punto work 100/100
  12. The Following User Says Thank You to jokersat For This Useful Post:
    mdanilo (13th May, 2013)
  13. #11
    Jun 2009
    can you show the connector wiring please ?
  14. #12
    IAW59F M3 immo off???
  15. #13
    morocco/fbs
    yes
    immo off = tested
    virgin = tested
  16. #14
    morocco/fbs
    Quote Originally Posted by racin-snake View Post
    for ECU ? or what
  17. #15
    dimitar's Avatar
    for ECU ? or what
    everything you can post mate
    50w Soldering Iron
    Chisel
    Sometimes Hammer
