Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    aissa09's Avatar
    Blida Algeria
    @m3mpower
    I'm happy for you
    Best regards aissa
    AISSA SERVICE ELECTRONIQUE
    BLIDA car radio decode
  2. #17
    Spain
    Quote Originally Posted by aissa09 View Post
    @m3mpower
    I'm happy for you
    Thank you for your help
  3. #18
    just a general question:
    This unit (ALPINE) is protected either with IMMO or CODE
    So, if the radio is installed in original car it will not ask for the code right?
    But if installed in NON original car then you need code to activate it? Is code enough to activate it in this case or dump must be changed as well to disable IMMO?
  4. The Following 2 Users Say Thank You to Rdecode For This Useful Post:
    arık (22nd December, 2014), Hashim1 (21st January, 2024)
  5. #19
    Nov 2010
    Default CD53 R50 DISABLED
    Please need your help to disable Alpine 24c32 CD53 R50 stereo
    thanks for help me
  6. #20
    Mar 2014
    Hi all,
    need fix Alpine cd53 r50 show Disabled.
    here is dump
    http://www.2shared.com/file/pAsn1ht8...ABLE-RADI.html
  7. The Following User Says Thank You to xtoni For This Useful Post:
    REZON (15th April, 2016)
  8. #21
    Mar 2018
    bonjour
    je recherche le code de mon autoradio alpine cd53r50
    s/n : AL501140281378
    MEERCI BEAUCOUP
  9. #22
    shooting's Avatar
    WALES
    Quote Originally Posted by barbier View Post
    bonjour
    MEERCI BEAUCOUP
    Use English only here...!
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  10. #23
    Mar 2018
    hello
    please help me for the code a radio car
    thank
  11. #24
    GB
    Wink
    :graisse:00000FE0) 99 12 00 99 12 00 99 12 00 00 ......... 00
    oui le code 1111 merci camarade
  12. #25
    shooting's Avatar
    WALES
    Quote Originally Posted by khayri View Post
    Use English ONLY here..
    wbr
  13. #26
    May 2020
    I need a fix if is posible, Radio CDR53 R50 S/No. AL 5007 2 08 23794
    Show Disable, dump in attach, not original car.
    Thanks!
  14. #27
    Jun 2018
    CD43
    Quote Originally Posted by Rdecode View Post
    Hi Rdecode, for everyone else information...
    This radio is unlocked by bmw iBus signal when communicating with the cars system. Yes R50/R53 mini cooper is BMW. There is no fancy special code inside the vehicle iBus system, this radio only looks for iBus communication of any kind. Best way to unlock ~DISABLED~ is using the steering wheel control pods on your bench testing station. You just need to connect the iBus data cable between radio and control pod and give +12vdc and ground signal to control pods and radio. OR you can use BMW E38 or E39 MiD (Multi-information Display) since this also has iBus communication.
    I will try @aissa09 solution and see what needs to be changed in EEPROM to listen for CODE instead of iBUS messages.
    Cheers
  15. The Following User Says Thank You to rocktumbl3r For This Useful Post:
  16. #28
    May be will be enough easy i-bus keypad emulator ? Tested with old radios like BM54, but not have now new units for test.
  17. The Following User Says Thank You to neeewww For This Useful Post:
    bogege (28th March, 2022)
