Albert G (24th January, 2019), google55 (24th January, 2019), petronijul (24th January, 2019), REZON (24th January, 2019)
Hello friends!
I need a code for Opel Delco radio: SN GM0500T9033409 Thank you!
Does the first schematic from here: http://blog.perquin.com/blog/category/odbii/ work as a converter?
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
Thank you! Is seems that it's time for me to start decoding. Unfortunately I don't have max 232 ic to hand, but i will buy 2 or 3 pieces, as it's quite cheap... Good think that I have experience in electronics
Interesting idea, but I will build the MAX232 based interface, as I already have an old laptop with serial port. I will come back to you as soon as I will get the job done. Thanks.
@skrubal your code is 0769 Regards Fradebo
@ConCon Your code is 9657 Regards Fradebo
@ iuli10 Your code is 2581 regards Fradebo
Hello friends !
I finally built the interface... Here it is:
But for me it works a little strange... It shows a code only when the laptop comes back from Stand-BY Otherwise it shows ”error”
Besides this it shows 2 different codes :
First one:
This is shown regardless of the state of the radio (ON or OFF), or regardless if pin +BATT is connected with +IGNITION at the +12v source, or if i only use +IGNITION.
The second code:
This one is shown if both +BATT and +IGNITION are connected to the 12v source, and after I press simultaneously the AS and ON/OFF knob. Mounted in the car, the radio shows 7SAFE after I press the above-mentioned buttons. Which of the 2 codes should I use? How can I reset the number of tries for the code?
@Fradebo, thanks for the code, but the person from which I have bought the radio told me that it is ”permanently decoded” (Yeah, sure, it seems that I've been double crossed by him), so someone else may have tried to change the code...
Thank you !
If blocked then only way is to read TMS370 processor, but be careful it blanks easy with programmer
wbr
7safe gives you a wait of about 30 minutes.
Just leave it on and wait until it changes. Then put in 1 of the codes. If not OK you have to wait longer...
The set is blocked after 10 attempts. After succesful input you change to zero.
Have you tried the original code that I gave you ?
regards Fradebo
PS There is no such thing as permanently decoded.
The code is always there. You can deactivate it by entering and confirming it twice.
