TGS220 cannot change image (TGS220 != NO SUPPORT) ?? :S
Results 1 to 15 of 28
    Apr 2011
    Default TGS220 cannot change image (TGS220 != NO SUPPORT) ?? :S
    hey guys i have an issue with an itgate tgs220 receiver. i had installed a darkstar2 image but now i want to change it back to the original image tht i downloaded from itgate.co.kr. i flashed the box, did a factory reset, tried almost anything. but when i try to update the box from control center a message comes up saying "TGS220 != NO SUPPORT"
    i chose darkstar because from there you can download any ccam files you want. but when i installed it and tried to scan for channels then only a few came up. not what i expected. i also tried adding the sattelites.xml file with all the transponder but no luck again. so now i am trying to go back from scratch with the original image and try my luck with installing manualy an mgcamd and ccam wich i couldnt install before by the way and believe me i tried everything that i had read in a lot of forums...
    anyone has a clue of whats worng? im desperate!
    May 2008
    Are you uk based?....have you tried to seriel update?...and what imaige are you trying to install?
    Bit more info required.......
    Apr 2011
    im in cyprus. i was trying through lan with control center. now i plugged in the serial cable and i am finally upgrading the box to edg nemesis 4.4 but its taking ages. do you know if i will be able to download mgcam and ccam on the box? or will i have to manually install them and if so how do i manually do that?
    thanks, im driving mad here
    May 2008
    you willl need to add extra url ft into var/etc and change attributes to 755....then you will get access to cams you require
    extra url last post here
    http://www.digital-kaos.co.uk/forums...ml#post1064965
    Apr 2011
    ok now i have another problem. i have a diseq switch connected with 2 satellites. nilesat and hotbird. did the configuration correct and did a multisat scan. only found 271 channels on nilesat and 291 on hotbird. that cant be right. any ideas?
    May 2008
    unsure of your set up...but i normally have to scan 3-4 times to get whats expected with my itgate...
    Apr 2011
    i went to a ur image i had and everything works fine. scaned just one time and got all channels. the only problem now is how to install manually the mgcamd. anybody has an idea? i think its not the same way as ccam...
    May 2008
    why install manually?.....did you add the extra url?
    Apr 2011
    oh no i just saw that. i just added the extra.url file to var/etc
    notice that my image now is ur. so what do i do next? when i go to the blue panel to download the cam files it says no connection... sorry if am i bit novice o these things
    May 2008
    want work with ur,..put edg-nemesis bk on,....the ftp into the box and add the extra url to var/ect....attributes to 755,..then reboot box..then blue,blue then option 2..mgcam if your after that 4th in the list
    Apr 2011
    but with nemesis i have the issue of the channels. it finds only 300 channels. dont know whats wrong with that. i also added the satellites.xml file with all the transponders but still no luck. so i have to stay with ur image but i just have to add manually the mgcamd. if anyone has a clue how to do that please HELP!!!
    May 2008
    ftp the cam into the temp folder then manually install
  13. #13
    May 2008
    Be nice to no if you got sorted?
  14. #14
    Apr 2011
    havent tried it yet. but i dont think it will work because i tried the manual installation before and i just couldnt get it to work. if you could guide me step by step how to manually add the mgcamd i would be greateful...
  15. #15
    May 2008
    what ur imaige you using?.... in all honesty i,v never been able to manually install,....when i get a imaige to work,..i always bk the var up,..or bk mtd4 in web interface,..then reflash if required.
