Page 6 of 6 FirstFirst 123456
Results 76 to 80 of 80
  1. #76
    Sep 2010
    HD Glass16 ver. 3.79
    - added selecet picon_default, next, marker... black/white
    - added enable/disable OLED off in standby
    - help updated
    - code optimalisation - acceleration
    Update is also available online via setup
  2. #77
    Sep 2010
    HD Glass16 ver. 3.91
    - fix support for plugin EMC 3.0.0
    - fix detection of Nemesis image 101r1( do not use this and next versions in older version of Nemesis)
    - fix icon type 1
    - icons in download updated
    Update is available online via setup
  3. #78
    Apr 2011
    Default Re: fix
    Quote Originally Posted by kalifornia View Post
    Hi all
    Is there anyone that can help with this problem?
    as i said in post 70 i am using hd glass 16 v 3.68
    downloaded from tunisiasat the skin is excellent except when you press blue to go to the blue panel i.e. addons it crashes to the green screen, it happens on all versions of HDG 16 but not 15
    i have checked the crash log but can't find the problem.
    any help would be appreciated as this is by far the best skin out there........
    my set up is
    Original Dm800HD edg nemasis 2.1 in flash.
    usb and hdd installed
    Could you let me know how you managed to fix this?
  4. #79
    Mar 2012
    Does this skin work OK with Vix 2.3
    Cheers
  5. #80
    Sep 2012
    hallo,
    i wil see first wat the skin emage!!!
