HD Glass16 ver. 2.85
- changed priority to get hdd temp in user info
HD Glass16 ver. 2.84
-added universal bin to get hdd temperature - autodetect and manual ( images without smartctl and with broken enigma hddmanager)
HD Glass16 ver. 3.13
- changed: name of satellite is generated from satellites.xml
- changed: service description set to yellow - channel selection with pig
- added colored bar for event-progress in channel selection
- added new type of oled: VU+ (for VU+ users)
- fix utf8 encoding in some images
- small code optimalization, messages correction
Hello Guy's
could you please help me I've got a solo box being delivered in the next couple of days what will I need to watch Arabic TV and and sports channels will I need Cccam ? or can it do the "magic" on it's own with the correct firmware sorry if this should be on a thread on it's own
I have a Starview combo and 1M motorised dish
COV
HD Glass16 ver. 3.47
- fix detection of the reference in channel selection
- fix session cascading (visibility) if permanent extra infobar is disabled
can you tell for my how install your skin on GM990 spark with enigma2, please
its not my skin mate i just repost it here. also i'm not sure about your receiver but on other e2 images you ftp the .ipk file to the tmp folder on the receiver and install via the menu.
thank HD Glass16 ver. 3.47
HD Glass16 ver. 3.49
- added new option: "update chceck" in setup - press button 7 - here you can check available updated online versions of the skin, if updated version is available can be installed immediately (autodection mips/sh4 and autodetection ipkg/opkg)
- small update piconProv (thx ftryskac)
Hi Guys
HD Glass 16 v 3.68 with edg nemasis 2.1 on DM800HD
Crashing on blue button press. Useing none button menu.
Any fix?
HD Glass16 ver. 3.66
- added new download menu in setup
- used 1 path to all types picon-s, help and sets of icon, ipk has a size of 2.7MB
- optimized code, better use of ram
- picons are available in white and black
ipk not contains piconProv, piconSat, piconCam and set of icons / previews, after update can be downloaded via the to download menu: all of picons, help and icons, ipk contains a
default set of icons - 1, before the download must set the path, that is used for all Picon, help and icons, definitions piconPaths.conf are no longer used, the file is removed from the ipk
update is available online through the skin setup
Hi all
Is there anyone that can help with this problem?
as i said in post 70 i am using hd glass 16 v 3.68
downloaded from tunisiasat the skin is excellent except when you press blue to go to the blue panel i.e. addons it crashes to the green screen, it happens on all versions of HDG 16 but not 15
i have checked the crash log but can't find the problem.
any help would be appreciated as this is by far the best skin out there........
my set up is
Original Dm800HD edg nemasis 2.1 in flash.
usb and hdd installed
All Fixed.
Does this skin work OK with Vix 2.3
Cheers
