Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 86
  1. #46
    Apr 2018
    HI I'm Looking for perkins flash files for perkins 2506A and 2506C engines.
    The ECM has this number printed: 262-2878-01
  2. #47
    Apr 2018
    thank my friend very good !!
  3. #48
    Feb 2012
    amman-jordan
    Hi guys, please your help to found the flash file , 314-6289-00
    for perkins 2506A TAG2 50/60Hz
    Best Regards
  4. #49
    Feb 2012
    amman-jordan
    engine serial no : MGBF3058U12256T
    Best Regards
  5. #50
    Oct 2010
    Hi my friend...please help me with this flash file: 3105773.
    Thanks in advance
  6. #51
    Jan 2017
    Hey Friend .
    kindly i need flash file of power wizard 1.1: 450-9630-00
    Gen set Fg Wilson
    Model P220HE2
    Thanks In Advance
  7. #52
    Member ukrainiandisel's Avatar
    https://www.facebook.com/ukrdisel
    Default 2506A TAG2 50/60Hz
    Quote Originally Posted by nadham View Post
    flash for perkins 2506A TAG2 50/60Hz
  8. The Following 3 Users Say Thank You to ukrainiandisel For This Useful Post:
    HALEEM88 (16th September, 2019), jokey (1st November, 2018), minasalama (18th June, 2019)
  9. #53
    Hi dear friends,
    I am looking for flash file for perkins 2806 C.E18TAG1A. Ecm part no. Is 372-2905.
    Thank you very much.
  10. #54
    send Engine s/n
  11. #55
    Hi, can you provide serial no for this Gen set Fg Wilson Model P220HE2 ?
  12. #56
    Feb 2019
    i would like to reflash a 3054E perkins/cat on a bandit chipoper. I was wondering if you can rerate the hp higher? thanks in advance
  13. #57
    Aug 2011
    izmail,ukraine
    Hi !
    Looking for flash file for perkins 1300 series \ mine was damaged by water\ international dt530e installed on combine claas lexion. I swapped ecu from donor truck,replaced memory chip 28f400, but original flash damaged partially.
    any help is greatly appreciated !
    all info in attachments
  14. #58
    Jan 2018
    i want it too if you found ols send me .. i want flash file for 4787932
  15. #59
    Jan 2018
    pls hellllllllp me guys i need flash file 478-7932
  16. #60
    Jul 2019
    hello i need 2206a flash file please
