Results 1 to 2 of 2
    Default hyundai accent immo info
    hello mates
    today i had the chance to solve the common problem with hyunday accent immo fault.....
    it is a faulty relay which cause this problem......
    it is located at the drivers side,up to the fuse box....it is the only relay which has one 6mm screw...!
  2. The Following User Says Thank You to d.zio For This Useful Post:
    bobbik (15th February, 2018)
  3. #2
    DK Veteran bobbik's Avatar
    EUROPE
    It's very useful info! I was about to made immo off -which isn't so easy in kefico 1.5 12V.
    Smartra immo box+antenna located on ignition switch.Check ignition feed voltage on pin 1 (or4) pink (or pink/black).
    If there is no voltage, check relay bolted upside down onto driver "A" pillar, and because of this, was full of water.
