Page 14 of 25 FirstFirst ... 491011121314151617181924 ... LastLast
Results 196 to 210 of 361
  1. #196
    Quote Originally Posted by einet View Post
    what is the benefits to make update to xprogbox and back to xprog-m?
    Are the firmware new?
    Orguinal?
    That is good question!
  2. #197
    ALGERIA
    Quote Originally Posted by martin292009 View Post
    1er run whit my dumps... xprogbox... and update...
    2er erase Xprogbox from pc...
    3 install xprrg-m 5.0 is in DK...
    4 run normal xprog ...
    THANK YOU MARTIN
    i have update my xprogm firewire and it work fine,and i keep all authorization,but it don't solve the probleme of HC05B16,the 3 first read was good,verify without mistake,then all the read verify come with mistake!!!!
    thank you again mate
  3. #198
    ALGERIA
    i think it's time now to apply the idea of adam380
    where i have to copy-past all the files (without 3 files) from xprogbox folder to xprogm folder
    and my xprogm will work like xprogbox
  4. #199
    smokey08's Avatar
    Essex, UK
    Quote Originally Posted by grinovsky View Post
    I have same problem with hc05b32 3G96A. Please report back if it works or not.
  5. #200
    ALGERIA
    WORK PERFECT WITH MASK D60J
    I CAN WRITE THIS MOTOROLA CHIP AS I LIKE WITHOUT MISTAKE
  6. #201
    ALGERIA
    not so good
    only the 3 first time was good,then it make error when verify
  7. #202
    dimitar's Avatar
    not so good
    Which 3 files have you omitted from xprog box software
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  8. #203
    ALGERIA
    this is a vedeo read/write motorola D60J
    Hotfile.com: One click file hosting: newfile.rar
  9. #204
    ALGERIA
    Quote Originally Posted by dimitar View Post
    i have copy all files with BOO and boo extantion,from XProgDesktop folder and from Cfg folder
  10. #205
    ALGERIA
    now,i try my xprogm on MCU 68HC912D60 from clio airbag ecu(in circuit) and work fine,read/write ,no probleme
  11. #206
    ALGERIA
    but,the best result,i get it when i use externel power 12v 1,25A(max)
  12. #207
    Jun 2009
    if you do not have a good usb port you must use a external power supply for best results
  13. #208
    ALGERIA
    before update,i nerver read this HC05 without errors
    and now,in most time i can read/write this chip without error,only in fwe time i get error when verify
    so,the update have solved the probleme of read /write HC05 chip
  14. #209
    ALGERIA
    now,i copy all files from xprogbox folder to xprogm folder
    without only 3 files,the 2 .xml files and .exe file
    work fine
  15. #210
    bram380's Avatar
    Indonesia +628153111774
    don't copy 3 files:
    1. XProgDesktop.exe
    2. Source.xml
    3. Configuration.xml
    See detail at here:
    how to update xprog-m 5.0
  16. The Following User Says Thank You to bram380 For This Useful Post:
    mexanico1971 (4th September, 2016)
