Page 7 of 25 FirstFirst ... 2345678910111217 ... LastLast
Results 91 to 105 of 361
  1. #91
    ALGERIA
    i am sure that no think change before and after update because the new files that you had copi/paste use the new fireware(update atmega) to work and you don't update the firewire
  2. #92
    ovi_dk's Avatar
    On board
    Normal,if i update the freware i must to pay for all autorization,i speack with the Drius and toldme that
    ,,I want to inform you, that xprog-box hardware made in china, fully
    electrically and visually inspected by our side and updated with
    original firmware and
    software.,,
    and to update all autorization i must to give 234 euro,for now its ok the soft wath i have,maybe pass a time i will make updata freware but now noo
    BR
    If u have the answer say Thank You!!
  3. #93
    May 2009
    hi
    where are pins of atmega for program pcb blue in circuit
    miso and mosi ?
    2 and 3
    or 12 and 13
    i try in 2 forms and not succes
    can somebody help me?
    regards
    many thanks
  4. #94
    Quote Originally Posted by morito View Post
    hi
    miso and mosi ?
    2 and 3
    or 12 and 13
    regards
    many thanks
    Run Xprog software, then select MCU/MPU - Atmel - ATmegaXX.
    Press "Show Connection Diagram" button and you will see.
  5. #95
    May 2009
    hi
    I try whit this but not work
    can I program in cirtuit or need desolder?
    the programmer works perfect in atmega162 to probe
    the ponyprog said error-24
    any help is apreciate
    regards
  6. #96
    spychu14's Avatar
    May 2011
    POLAND
    For me ponyprog work perfect. Remember about VCC to atmega
    Anyone have schema for xprog-m or PCB scans ?? thanks
    VAG
  7. #97
    On Xprog-m, I think both SPI interface (12 and 13) and Jtag interface (2 and 3) are disable.
    hi
    regards
  8. #98
    May 2009
    I try pins 2 and 3
    pins 12 and 13 but not sucess
    only in circuit.
    somebody program in circuit in pcb blue atmega?
    many thanks in the advance
  9. #99
    Quote Originally Posted by agabna View Post
    THANKS
    BUT HOW WE CAN DOWN GRADE FROM 5.3 TO 4.5
    Search - Downgrade XPROG to V5.0
  10. #100
    DK Veteran agabna's Avatar
    Quote Originally Posted by bolonc View Post
    thanks but they need to send money
    Is their any other way without paying
    yes i know you can got every thing free
    but some times u need to do that
  11. #101
    stefaudio's Avatar
    BULGARIA
    Default IN CIRCUIT PROGRAMING OF X-PROGM
    solder on board
    miso--pin3 of atmega
    reset--pin20 of atmega
    sck--pin11 of atmega
    Lift pin2((MOSI)) of board
    Appli 5volt on electrolt capacitor near to atmega dont power all programer wit usb or adapter
    use PoniProg
    This metod tested bi my work 100%
    I reed securiti and configuration bits and dei are..
    Lock1 and Lock2 ---activ
    CKOPT---activ
    BOOTSZ1---activ
    BOOTRST---activ
    SUTO---activ
    BODEN---activ
    BODLEVEL---activ
    my x-prog work good but the atmega is locket
    regards frends
  12. The Following User Says Thank You to stefaudio For This Useful Post:
    mexanico1971 (4th September, 2016)
  13. #102
    stefaudio's Avatar
    BULGARIA
    Original my programmer hav Atmega64A AU inside after repair its wit Atmega64 16AU
  14. #103
    makura's Avatar
    I put the 100k across the transistor but i still cant read HC05 (0D60J).stuck on bypass security.tried hc11f1 device is silent.
    I have one with the green board.
  15. #104
    makura's Avatar
    any help please guy,what else can i try,cant go the xprog-box raute
  16. #105
    I also can't get something for nothing.
    I just have XPROG-M all versions of dump(4.5,5.0,5.35),
    I can Modify the software,
    so,Don't need eldb things.
