Results 1 to 15 of 18
Thread: KWP2000 problem
    DK Veteran VTS_Tibi's Avatar
    Hungary
    Default KWP2000 problem
    Hi Guys,
    I've bought this "tool" a few years ago but never really used it...
    Now, when I would need it (reading a Smart 800 CDI ECU) it does not work...
    I have the interface installed on a laptop with Vista operating system. It recognises it as it should - serial K Line interface.
    I open the KWP soft., select the Smart from the list, and when the window pops up, it shows: "kick not found"
    What can I do to make it connect to the car?
    I've tried connecting it to the car via the OBD cable! I've tried it on a Xsara HDI, and receive the same error!
    Could the problem lie in the fact that I use the OBD cable?
    Should I try to read the ECU out of the car?
    Hungary
    it's the same car, same interface, same method, but still no luck:
    [ame=http://www.youtube.com/watch?v=jBCgdfo_HQc]YouTube - KWP2000 ohjelmointilaitteen k?yt?n opastusta[/ame]
    Top Poster grimmer's Avatar
    Dec 2010
    norfolk uk
    u do have the ignition on dont you?
    Car Diagnostics
    w.yorkshire
    klick not found is driver issue. soft not find device. try on xp machine as im sure kwp2000 was never made to run on vista. regards steve
    Dec 2010
    norfolk uk
    yeah also second that ive never got kwp2000 to work on vista, only 2000 and xp
    Car Diagnostics
    Hungary
    ohhh... okay! Thanks guys!
    will try it on my other laptop, as it has a virtual XP on it (next to Win7) which I Use fro PSA XS Evo.
    Hungary
    tried the KWP2000+ on XP and the results are the same... Kick not found!
    what the heck could be this?
    could the problem lie in the bad driver?
    maybe offtopic,but knows somebody if the kwp2000 software work with this interface?eBay.be: DigiFlasher Black Edition Chip Tuning Chiptuning NEW... (object 180648671292 eindtijd 06-apr-11 19:01:04 CEST)
    best regards
    Dec 2010
    norfolk uk
    you most proberly have a bad tool, lots out there, they are hit and miss galattos and kwp2000 units being clones.
    but is this the same car u having problems with the ecu on the other topic?, if so the kwp2000 may not be able to wake the ecu.
    Car Diagnostics
    Hungary
    Quote Originally Posted by grimmer View Post
    yeah, the car is the same, Smart 0.8 CDI
    The ECU works if the flash memory is cooled down, so I even able to drive the car with the frozen ECU - and when I tried the readout, the flash was cooled down
    yesterday I spent my whole day trying to read out the dump from the ECU - at the end of the day on around the 3rd. computer with XP, and the ECU on table I managed to read out ECU data, and started reading the dump out, but it always stops at 2%...
    so my KWP is a big useless brick!
    I'm on the hunt for a Galletto
    Elsewhere
    Please m8, do you have a KWP2000 interface schematics ?
    I want to make one.
    Something, a link, a hint where to find the schematics ?
    Anything will be welcomed ! Thanks !
    Hungary
    Here it is - as far as I remember it's from someone here
  13. #13
    Elsewhere
    Quote Originally Posted by VTS_Tibi View Post
    You`re great, my freind ! Thanks one more time !
  14. #14
    Enable Slow speed in the menu and should works.
    Don't forget to touch thanks button.
  15. The Following User Says Thank You to vwpassat For This Useful Post:
    speedy100 (1st August, 2017)
  16. #15
    Oct 2016
    thx! work
