Page 9 of 19 FirstFirst ... 4567891011121314 ... LastLast
Results 121 to 135 of 285
  1. #121
    DW190
    Guest
    Quote Originally Posted by CrAcKeDuP View Post
    Should this firmware work with the S9, as when I tried it only the network and USB functions were available. Every other setting in the menu was blanked out....any help much appreciated.
    Probably because all the channel list has gone and all other settings.
    You sure the sta scan has gone as well? If it has you will need to reflash.
  2. #122
    DK Veteran ASTROBOX's Avatar
    Singapore/Indonesia/Malaysia
    Default Openbox s10/orton clone box
    Hi to all quite new to this box recently download the abs file for Europe to try on the media player issue that i'm facing with the default software i recieved from the supplier in China,for info mine is a clone set i guess.
    ok after download this file i edit the satellite list to suit my region that is SEA using C band motorized dish FTA channel,use the usb stick to upgrade the firmware wallah! all the list is there & got no issue playing mpeg & vob video i'm so happy now that i can use both format for my S10 & Dreambox 800hd thanks for this great firmware.
    PS : Still got a lot of reading in this forum for S10 box
  3. #123
    Default S10/Orton Clone
    Just to update using Openbox_s10_nds abs file found in #99
    more stable for clone set, i'm using it right now however the media player won't auto play to next video eg music video is like individual file try to rename it using serial no still the same any expert can guide on how to solve this, can it be play without stopping like DM800?
  4. #124
    Default Openbox S10
    Sorry all bro mine i confirm check is original, the chipset is 00EA
    So it should be original S10.....
  5. #125
    Nov 2011
    Default S10 firmware
    Hi guys this is my first post, i've successfully put in new cc@am lines on S10 but its freezing all time, what the best firmware please, this is my first post!
  6. #126
    Nov 2011
    Wellington, New Zealand
    Default Skybox S10
    My STB is branded "SKYBOX", and the splash screen at bootup displays "SKYBOX". I was told that SKYBOX and Openbox were the same.
    Can I install this new firmware on my SKYBOX S10?
    thanks!
  7. #127
    DK Veteran termiantor's Avatar
    Jan 2009
    yes you can mate
    HAD THE PARTY LOL
  8. #128
    Nov 2011
    Thanks Termiantor... and can I come to that party?!
  9. #129
    Nov 2011
    Firmware Upgraded. Splash screen now says Openbox. I had to do setup from scratch - including entering satellite location for the satellite we use in New Zealand (Optus D1). All OK now.
  10. #130
    Nov 2011
    Default abs / dbs ?
    I have an openbox s11 thaat seems to use .dbs format but all firmware downloads seem to be .abs do i need to convert or just change the extension ?
  11. #131
    Newbie a3nca's Avatar
    CCcam does not cause the box to freeze, it's either the server that you are using or your internet connection or both!
  12. #132
    Quote Originally Posted by termiantor View Post
    yes you can mate
    I'd like to come to that one and I'll be throwing one when Blair dies too! You are all welcome
  13. #133
    Nov 2011
    wow this forum is great!
    just wanted to say hi,
    is there a s12 box?
  14. #134
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    Post 12v
    Quote Originally Posted by codezs View Post
    is there a s12 box?
    12v external power supply,that looks interesting.
  15. #135
    Dec 2011
    can any one tell me how to upgrade firmware?
