enigma2 TSpanel plugin,everything you need for your image - Page 13
Page 13 of 13 FirstFirst ... 38910111213
Results 181 to 185 of 185
  1. #181
    Mar 2013
    Hi, Can I flash TSPanel manually using USB stick. I tried a couple of times and when loading it says 1 error.
  2. #182
    Mar 2013
    can you put on drambox 800
  3. #183
    Apr 2014
    Hi, unfortunately after reading up and down on how to install tspanel, I still can't get it right. I've downloaded numerous versions of tspanel, latest the one above here, extracted it and put the .ipk file in the /temp catalogue. I may add that I'm running Black Hole 2.0.9.1 (latest) image on my Vu+ Duo2 Box. Well, use DCC to FTP to /var/volatile/tmp and I can see the .ipg file being there. After this I enter the Vu+ menu, choosing to add .ipk, the Vu+ finds the file and tries to insall it, but while performing a check of the file, it Returns an errormessage, which is only visible for a short while, stating something about architechture mismatch or something like that, then the process ends in restarting the GUI. Anyone who has an idea of what I'm doing wrong? Because it is probably me who has overseen something :-) any comments would be highly appreciated :-)
  4. #184
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by Tommeliten View Post
    it's easier to learn to add add the extra's needed manually than using
    the ts panel, but if you wish to use it this is how to load it with the DCC
    use the latest E2 v1.50 DCC panel and load the tspanel this way
    you load the tspanel after the image of your choice is flashed
    open the dcc and click [TOOLS] then [packages]
    in the green section on the left of the panel
    a list of the packages on your box will upload
    under the list are two bar strips [update package list]
    and [upload package] click upload package bar a window will
    open find and click on th tspanel file then click open on the
    window the file will now load on your package list and will give
    the loading info in the protocol pane under the package list.
    once loaded,close the dcc and re start your box when it
    re boots you will find the tspanel in your menu list ready to use
    just remember to use the vu section and the items for the image
    you have on the box this method also works with dreambox models
    and i would think with every linux box models,but as above only use
    the the correct linux model section for all the extra's for the image your using
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
  5. #185
    Aug 2014
    Hi i'm trying to update my dm800 with this ts panel and for the life of me i can't get it to work. I install from local extension then reboot but is does not show up in menu? please help......from a newbie
