can somebody please post a link to the latest version of TSpanel
cheers
Used TSPanel on my Vu+ duo using method stated at 8th Feb and worked fine. Had updated to new VTI image 4.1 at time and wanted an easy method to do it. Only thing I find is that the Catseye setting are not always kept uptodate there so may need to use settings installers to keep it this way when things change.
cheers
Hi Guys need some assistance please
how do i install TSpanel into my a premium hd box not up on these things so a detailed tutorial if you please
this is valid for db enigma 2.is there something similar for enigma 1?
Newbie with VU+Duo. Is this ok to install with Black Hole latest? Just got box and trying to install cccam
yes m8 its ok with all enigma2 boxs install tspanal and you can get all the cams and anything else you need from tspanal
im using bh myself with tspanal
is anyone have any idea where is the emus saved in the tspanel??
Is there a way I can run a script in the background via the TSpanel?
I have just been looking at the TSpanel, and it showed an update (within SIM2), so I installed this and now it has vanished altogether.
I have then downloaded the file enigma2-plugin-extensions-tspanel_4.5_mipsel.ipk into the tmp folder. When I then try to install it it mentions something about 5.2 and won't install.
HELP Please!
CHEERS
EDIT: I have now solved this via the force-downgrade option.
please press the little red THANKS tab
if I helped if not press the green tab to tell me to f**Koff
sometimes life will kick you around , but sooner or later , you realize you`re a warrior , and your stronger than anything life throws your way !!!!!!!!!!!!!!!!!!!!!!
anyone please ???
madmex (27th November, 2013)
update to 5.4 version through the previous version should solve the problem with old images like phoenix dd
Installation:
copy attached file to /tmp
by telnet
opkg install -force-overwrite /tmp/enigma2-plugin-extensions-tspanel_5.4_mipsel.ipk
what does this mean?
with dcc open telnet and write this?
