Page 3 of 31 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 465
  1. #31
    DK Veteran superc0's Avatar
    MEXICO
    hi, bibms, how i can make a raw copy?
    this damage damage my cf card?
    i
    SOFT FOR ANDROS BENCH 6330 HELP PLZ.
  2. #32
    Quote Originally Posted by bibms View Post
    superc0 if you download bibms's file there is an app included that will make a raw image file of your CF card. You will need to have a CF card reader to make the image on your pc. Could you also make images of the 2 dvds.
  3. #33
    Aug 2010
    Quote Originally Posted by superc0
    i
    It won't damage your card. If you are familiar with command line do a search for 'dd win32' otherwise use the program that I included in the gen05 rar.. FYI the image to use is the 09 one. The first one had problems.
  4. #34
    Aug 2010
    FYI people I don't want to hear complaints about so and so not working when you don't even have the smart card to authoriZe that portion of the software. For example don't expect import to work when you only have a pathfinder smart card.
  5. #35
    MEXICO
    HI AGAIN I AM DOWNLOADING YOUR FILE,
    LET ME SEE THIS FILE WHEN FINISH.
  6. #36
    MEXICO
    Quote Originally Posted by NightDragon View Post
    THEY ARE CD FORMAT, I GOING TO TRY UPLOAD, REMEMBER MY SPEED IS VERY SLOW, YOU NEED THE ENTIRE CD? OR ONLY SETUP
    FILES FOR THE SOFT?
    THIS CD ALSO CONTAINS CONECTECHH SOFT AND OTHERS FILES
    THAT I DONT USE
    2 hours 54 min, for 100 mb hard job, now uploading
  7. #37
    Aug 2010
    FILES FOR THE SOFT?
    THAT I DONT USE
    That would be great. I have connectech for the 3.0 version but it doesn't like x64 wonder if the version you have will be any better.
  8. #38
    MEXICO
    yes have drivers for x64
  9. #39
    MEXICO
  10. #40
    MEXICO
    AS YOU ALL, THE LAST PART ONLY BE SHARED WITH THOSE 20 POST IN THE FORUM AND HAVE SHARED FILES IN DK.
    THE LAST LINK WILL BE SENT BY PM.
    AND ONLY IF YOU HAVE PRESSED THE THANKS BUTTON.
    THIS IS BECAUSE MANY MEMBERS ONLY TAKE WHAT YOU NEED TO SELL BY OTHER FORUMS OR SITES FOR SALE, I HAVE IDENTIFIED SOME OF MY COUNTRY BY SELLING MANY DIFFERENT MEDIA FILES AND GET THIS GREAT FORUM.
    MY APPRECIATION TO THOSE WHO SHARE YOUR FILES NONPROFIT
    SORRY FOR MY BAD ENGLISH
    TRANSLATED BY GOOGLE.
  11. #41
    Aug 2010
    Thanks.. I will definately check it out when I can. I totally agree with you about the members who are only here to take for their own benefit (most likely for their pocket) that is why I didn't bother much with trying to bypass the protection scheme all together. I do believe I made a good decision about requiring the old smart cards. The genisys is a good platform. And I do encourage people to atleast buy the software from the 'Real' developer. Cause if the sioftware helped you, then you should consider helping them by buying it.
  12. #42
    ok i finally got the gen-09 final to load but everything but domestic and euro dont work for me
    (select domestic,select gm,tool shows 4.0 loading screen then kicks you back to the domestic mfr. selection menu)
    same thing for everything i tried in euro but asian appears to be working fine
    abs/airbag kicks you back to the menu too
    tpms appears to be working
    using genisys (3.0 updated to 2008 with smart cable)
    i have tried reloading it, same thing
    any idea as to what im doing wrong?
  13. #43
    Quote Originally Posted by scotte View Post
    My friend if you follow the earlier threads you MUST have the ABS/AIR BAG, Euro and Pathfinder SMART CARDS for that Machine or the update will not work for the software you mentioned.
  14. #44
    Quote Originally Posted by shitad View Post
    i have them
    i have domestic,asian,airbag/abs, 2007 and 2008 cards as well as pathfinder (infotech w/scope also)
  15. #45
    Aug 2010
    i have them
    I may have left out something since I only have tested it with 2003 smart cards. I will look into it. Most likely I left out something. I'll check it out when I get home. Hopefully I'll be able to just make a patch that you can apply to the image file. I just remembered something. The smart cards you have must have been authorized on your scanner before. If they were authorized first on a different scanner it won't work.
