Results 16 to 30 of 44
  1. #16
    Land of Rocks
    I read this mcu with UPA at 5V power delivered by programmer and never fails.
  2. #17
    DK Veteran wsc's Avatar
    GR
    Yes but in my case the UPA can not read 3L80R secured
    Smart car engineer ,
  3. #18
    Top Poster bijlaard's Avatar
    May 2011
    Elst - Netherlands
    Quote Originally Posted by grinovsky View Post
    MC9s12DG128B must be powred only by 3.3v,
    the 5v will distroy the chip
    I just puttet 5 volts on the original input from the dash and slowy made it go to 13,8 volts.
    at 6,5 volts the chip had 5,0 volts , it stayed 5,0 volts until the 13,8 was reached.
    I did not test what would happen at 20 volts .....:-)
    So I think my chip(s) need 5 volt.
    So bad,( for me) it's not the solution to my problems
    any other suggestions ?
  4. #19
    ALGERIA
    this is you chip
  5. #20
    Hungary, Mosonmagyar?v
    Hi!
    I read same mcu with x-prog_m ver.4.5 on volvo v70 2007 dash.
    Last year I dont have problem my x-prog.(I use with micronas , mpc , secured mcu...)
  6. #21
    May 2011
    Elst - Netherlands
    this is you chip
    Sorry for maybe stupid questions,
    When I leave gnd on the dash and give the + an external 3,3 volts would that work ?
  7. #22
    ALGERIA
    yes ,work fine
  8. #23
    Jun 2009
    i never use power supply to xprog . usb can reach the 5 v and also 9 volts .
  9. #24
    That's not true. Read datasheet. 9S12DG128B works with 5V
  10. #25
    ALGERIA
    no,read the thread and you will find that this guy have distroy 50% of his chips by using 5v
    but if you can give to us other reason!!!
  11. #26
    That is just bullshit. I read/write several 912, 9S12 and 9S12X
    they all work with 5V. Just read datasheet and you will see it.
    Possible reasons could be everything starting by bad xprog clone, activated security which results in locked bdm port.
    first step solder coax wire and check if xprog-m works with 9s12 secured option. in this case it should bypass security and connect to it.
    second step is desolder mcu and read with xprog using parallel programming.
  12. #27
    micromax's Avatar
    South Poland
    Vcc out from xprog is regulated 0-5V. if you kill motorola maybe you select wrong device and xprog not regulated corectly Vcc? or your xprog is faulty.
    additional resistor to vcc is unnecessary.
  13. #28
    May 2011
    Elst - Netherlands
    We did measure the volts it is 5 volts that comes out of the Xprog.
    We selected MC(s)12 and then the MC9S12-Flash
    What do u mean with :
    solder coax wire ,..where should we do what ? :-)
    (we are real newbees , sorry) do u have a picture of what we should do ?
    and what do u mean with parallel programming ? Thnx
    greetings Ina and Obbe (beginners from the Netherlands)
  14. #29
    Select Motorola HC(S)12-secured -> MC9S12-FLASH-secured.
    Click show connection diagram. then you will see that it needs to additonal wires (coax signal + gnd for shielding)
    extal has to be connected to the oscillator pin. the other one to gnd.
  15. #30
    May 2011
    Elst - Netherlands
    ok wil try that
