http://www.digital-kaos.co.uk/forums...te-dish-11239/
try that and get back in touch........
Read the Rules here; they apply to EveryOne.
__________________________________________________
DM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Technomate 2300 motor powered by UsalS
good afternoon mr juleet and wecome to the site, i had a similar prob set disc and usals check long+lat or where you are in the world with a tomtom or other sat nav and if required set long+lat accordingly with tm remote cotrol be very careful not to press the wrong button or all will be lost and you need reset all sats. not the end of the world but a pain, you may as sid suggested have to get ladder to check the vertical angle which also is calculated by the long+lat that is the setable angle of the moveing motor shaft + the setable angle of the dish = correct setting there are websites available with the coordinates. regards rixton.
if your system uses the usuals motor settings
go into the receiver menu and go to satellite set up
and add the satellites you want on your list, save the changes
and then send the motor to them and scan the channels in
Please Read Carefully!
No Sky UK NDS Videoguard Hacking Discussions.
Viewing Pay TV without a valid subscription is illegal
the files available are kept for experimental & educational purpose only
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
As simple as that! Thank you all for your help, happy Christmas viewing to you all.
Going now to look at what I can receive on other satellites.
what was the actual solution????
TM500
DM500s
i reckon benny's was the solution.. he's a god around sat downloads
set your lat to 51.5n long 0000w if you carnt get it right take it up in stages ie 52.0 n 0001w after each setting press ok till you get yellow and blue bars at the bottom to maximum then save settings all are in usals ie diseqc motor 1.2 off usals hope it helps you out
TM500
DM500s
sorry sadiq999uk but i never read your post on sat setting to juleet i do appologise for that mate
