I tried to put BT into AT mode - without success.
There seems to be a nonstandard firmware in BT module.
pin-out maybe is standard
removed working module, connected on my desk - work OK
just no AT mode
why do you say bmw not working? do you have hardware with oki chip?
I have same issue woth BMWs. I have kit with the oki chip in, bit no comms woth new bimmers.. Drives me nuts..
oh, i will try tonight on an e65 to see...
l.e. doesn't work on e65 2001 735i ....
don't know if it's hardware or software related cause it cannot talk to any module, even on this e65 all modules can talk on k-line, so don't need DCAN...
HY everybody,
Just a little question: Is anyone have an idea of the exact polyswitch reference on the map relays interface and above the holding current?? marking component P200 or F200?
Raychem or TYCO or littlefuse manufacturing.
2A (holding current)and 8V apparently ???? But it'is a low voltage for me ?????
Thanks by advance for your respond.
Regards.
Titoun
There are some folks who found the problem but they won't share. I am trying to fix that for 2 months now but no success. I have a working and a non working interface, the main PCB is my problem. I exchanged components from the good interface to the bad interface (except the main MCU) but still haven't came to any solution.
Dear colleagues my English is not the best but you will understand me, I have a copy autoc with version 2011.3, with regard to passenger program works perfectly, even there are things that can not be my multidiag, a freight program does what it has obd else because I did not even try no one has the right arrangement of pins, I asked if someone would have origuinalne load cables to make the seeds and sent, thanks in advance
I have tested autocom 2011.3 on alot of makes and models where it works fine..
But i plugged into a 2002 ford transit with 3 different autocoms (All with the OKI chip fitted) but none of them communicated with it...There is battery voltage on 16 pin obd port.
I have also tested these on a 2005 focus 1.6 tdci which had full coms with all ecu's....look like autocom does not like the older fords...
Rdgs Ron.
Its always Nice to say Thanks...:-)
no, there are many bluetooth pins for clones 1234 or 0 or 0000
Hi everyone !
I have a problem with bluetooth, already try on 2 pc but can't see it, so couldn't connect . Anyone with a working unit can verify if soldered pin on bluetooth module are correct ? Thanks !
I can look tonight for you on my unit what issue are you having with the Bluetooth?
Sent from my Galaxy Nexus using Tapatalk 2
