I hear that meathead,bit like lending a car to an ex wife .same enviroment and effect .Many thanks for your hard work and input fifas
i get too nsis error when i try to install autocom 2011-3 on mine xp....
After bad upgrade for firmware ,CDP+ from customer looks like in photo when put in DLC socket.For resolve this,need reinstall software from DVD (2014R2) and make another time upgrade for firmware.Now CDP+ work fine.
Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
thanks to all
my prob not solved
best regards
what cars try for diagnose?with K-line or with CAN?many time problem is cable.try with another cable with OBD plug.
20160805_172422.jpgPlease help. My AutoCom Not communicating with Opel and Saab ...
what Opel?Astra H,Vectra C,Astra J,Insignia?This have CAN ,same SAAB.You try in Astra G?In another car work fain?I think you have problem with CAN,but need more explication.
bebyutza (14th August, 2016)
Saab 9-3 And Vectra C . I do not know others because I use personal interest
this car ,SAAB and Vectra C have CAN.In this case your Autocom have problem with CAN connection.Verify wire inside obd adaptor ,from pin 6 (CAN-H) and pin12 (CAN-L).
not having the can filter wont help with this hardware in its place there is only 2 000 ohm resistors which is just a bridge (shorted)
you should buy the filter and put this in the place
Can you be a bit more explicit about what should I do? A scheme please!
in red quadrat is CAN filter ,in green quadrat is transceiver for CAN.you can try change,ist not expansive.
