hi all,
I have a small problem,
my interface now has another serial number and can not work,
My software is version 2011,
how I can change number in interface?
I can upgrade?
appreciate some help
thank you very much in advance
hi all,
I can upgrade?
why your interface has another serial number ? what have you made?
Here autocom flash whithout pass.
Ver 2011.1 all id ok
sep382 (9th October, 2022)
Ok what i need to make my interface after this flash ? I think I need an SN to write in AT90LS2343 . It is true ? Please take me some deyails . Thank you .
Please can you send me the password?
Hi all,
install another serial number and now does not work,
to test the interface, connects well and I have this number,
not communicate with the car.
While LEDs are lit, the relay sounds inside
No communication error message.
someone can give light to the problem,
to return to work by car
thanks in advance
installed with serial interface, works well.
then install with different serial number on another computer,
no longer works on any PC,
the wrong serial is 30250,
when I test, recognized as 30250 no longer works.
29f800 and I can work to flash again?
I can do to return to good serial?
Come one, that is so simple.
Did you got yur "hardware key" from your supplier?
You must enter that key in your software.
Serial 30250 is vell known serial for all chinese clone units of Autocom CDP CARS.
For software 1.2011. (last software which you can use on clone units, if you want to reprogram your unit that you can use newer software from 2.2011 and up, please send me a PM), your hadware key is: AJVPYMEKPPDK
In software, go to: HELP, License and then enter key from above, presto your Autocom clone works!
Regards and respect!
anyone know if autocom with enable speed limiting option on a ford transit 2005?
That's great.
hello everyone I have a problem with the machine inadvertently Autocom have given the firmware update has stopped working and you have a solution or I have to send the dealer is not original clone.thanks very much
Thanks Ash
Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
